You're past that edge. Stop what you're doing and fix it. Replace thermal paste or the cooler.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1020490-max-temp-acceptable/#findComment-12183676
thats not acceptable. Time to upgrade your cooling.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1020490-max-temp-acceptable/#findComment-12183707
I got an i5 8600 and started with the stock cooler.
Firstly the noise was horrendous, it was like a plane taking off. Temps were way way high, thermal throttling aplenty dujring benchmarks and gaming.
I bought a pure rock slim for about $30 (IIRC) and now I don't get above 70 and I hear little or no fan noise.
i5 8600 - RX 6600 - Fractal Nano S - 1080p 144Hz
https://linustechtips.com/topic/1020490-max-temp-acceptable/#findComment-12183841
1 hour ago, federiver said:
see if you can change the voltage in the bios, all the way down to 1.15v, if not then a h7 will be do job, some AS5 (every penny counts on a locked cpu) or mx4 will do.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1020490-max-temp-acceptable/#findComment-12183965
Intel page says that the i7-8700 throttles down at 100*C so this means there's something wrong with the cooling and it decreases performance to not get past 100*C. Check if you have thermal paste under the heatsink. If you do, reseat the heatsink, get it off and put it back,be sure the pins are well pushed / screwed. Most likely the heatsink doesn't make contact with the CPU.
https://linustechtips.com/topic/1020490-max-temp-acceptable/#findComment-12184114
i would say wither get a 240mm aio (if you can afford one) or somthing like a coolermaster 212/ noctua NH-9UB SE2, like Xx_DonutEater_xX said
Have a nice day:)
PC:    CPU: Core i7 4790k   I   GPU: MSI GTX 1070Ti Armor   I   COOLING: Custom water loop (cpu and gpu)  I  RAM: 16Gb DDR3 1600MHz   I   SSD: Samsung 850 evo 500Gb   I   HDD: WD blue 1TB, Hitatchi 2TB, Generic 1TB   I   PSU: EVGA 500w
https://linustechtips.com/topic/1020490-max-temp-acceptable/#findComment-12184759
