Performance problem (RTX 2070)
Go to solution Solved by Monarch,
It's definitely because of single channel.
1 hour ago, Cereal5 said:
You're most likely running out of RAM in most of those games. I'm surprised you bought the parts you have and only managed a single stick of 8GB RAM. That, and it being single channel, are the most likely problems, though the CPU load at 100% is kind of a head scratcher. Do you have some programs running in the background? Maybe an anti-virus, or windows update?
Pretty much all latest AAA titles can utilize 16 threads, especially games like BF1 and 5, which are known to be CPU heavy. I get 100% usage on a 9700k, so 100% on a 8600k is completely normal and expected. It's only 6c/6t.
Hello everyone.
Yesterday I got RTX 2070 and started testing games.
First I had problem with Battlefield 1 dipping fps and stuttering, while fps is lower than it "should" be according to reviews. I searched for solution and I think single channel 8gb RAM is problem (cpu was on 100% while GPU wasn't). (Battlefield V similar)
Than I tested Shadow of the Tomb Raider and it ran again lower than reviews, but it seems that only scenes with many people dipped to around 40 fps.
After that I tried GTA V assuming it is older game so there shouldn't be any problems running it around 90fps but it ran surprisingly bad around 40-60 fps most of the time.
_______________________________________
In all tests I maxed out settings and it was 1080p
PC specs:
Processor: Intel(R) Core(TM) i5-8600K
Mobo: ASROCK Z370 Pro4
RAM: HyperX 8GB FURY DDR4 2666MHz CL16 single stick
GPU: NVIDIA GeForce RTX 2070 (https://www.msi.com/Graphics-card/GeForce-RTX-2070-ARMOR-8G)
PSU: CORSAIR TX650M
What do you guts think is it all because single channel memory or is there something else that could be causing the problem?
https://linustechtips.com/topic/1020467-performance-problem-rtx-2070/
My Build, v2.1 --- CPU: i7-8700K @ 5.2GHz/1.288v || MoBo: Asus ROG STRIX Z390-E Gaming || RAM: 4x4GB G.SKILL Ripjaws 4 2666 14-14-14-33 || Cooler: Custom Loop || GPU: EVGA GTX 1080 Ti SC Black, on water || PSU: EVGA G2 850W || Case: Corsair 450D || SSD: 850 Evo 250GB, Intel 660p 2TB || Storage: WD Blue 2TB || G502 & Glorious PCGR Fully Custom 80% Keyboard || MX34VQ, PG278Q, PB278Q
Audio --- Headphones: Massdrop x Sennheiser HD 6XX || Amp: Schiit Audio Magni 3 || DAC: Schiit Audio Modi 3 || Mic: Blue Yeti
[Under Construction]
My Truck --- 2002 F-350 7.3 Powerstroke || 6-speed
My Car --- 2006 Mustang GT || 5-speed || BBK LTs, O/R X, MBRP Cat-back || BBK Lowering Springs, LCAs || 2007 GT500 wheels w/ 245s/285s
The Experiment --- CPU: i5-3570K @ 4.0 GHz || MoBo: Asus P8Z77-V LK || RAM: 16GB Corsair 1600 4x4 || Cooler: CM Hyper 212 Evo || GPUs: Asus GTX 750 Ti, || PSU: Corsair TX750M Gold || Case: Thermaltake Core G21 TG || SSD: 840 Pro 128GB || HDD: Seagate Barracuda 2TB
R.I.P. Asus X99-A motherboard, April 2016 - October 2018, may you rest in peace. 5820K, if I ever buy you a new board, it'll be a good one.
Did you DDU in safe mode to install the drivers fresh new? but likely the single channel is bottlenecking you yes
Personal Desktop":
Luna, the temporary Desktop:
i7 9700K @ 5 GHz, ASUS DUAL RTX 3070 (OC), Gigabyte Z390 Gaming SLI, 2x8 HyperX Predator 3200 MHz
While you are here. Can I buy other stick of RAM that is the same but it has cl15 (HyperX 8GB FURY DDR4 2666MHz CL15)? Will dual channel work fine then?
Edit:
Thank you all who tried to answer my question
1 hour ago, Vegetto said:
it's best to buy the same ram, if not, both sticks will likely run at the specs of the slower ram. the 8600k does bottleneck a handful of multithreaded games past a certain frame rate around the 100fps  range regardless even if you oc, 6 cores/6thread just isn't enough for some games. But in your case, it's most likely just ram.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
9 minutes ago, xg32 said:
it's best to buy the same ram, if not, both sticks will likely run at the specs of the slower ram. the 8600k does bottleneck a handful of multithreaded games past a certain frame rate around the 100fps  range regardless even if you oc, 6 cores just isn't enough for some games. But in your case, it's most likely just ram.
Ok, thanks
