What would the reason be that I cant upgrade my Windows 10 64 bit home past version 1803? I know that there is a new version of windows out (1809). Ive tried using the built in updater and it runs but doesn't change the version, Ive also tried downloading and running Windows 10 Update Assistant, it knows I am on the old version, it says its downloading and installing the new version but low and behold once it finishes I am still on 1803. The only reason I even realized I was outdated was I was using 3DMark and to run the new RTX benchmark you need version 1809. Any ideas. For what its worth I am using an Alienware R17 R5
https://linustechtips.com/topic/1020247-stuck-on-1803/
does it fail with an error message or just doesnt beginn?
My Setup:
CPU: i7 4790 @3800 MHz, MB: MSI H87-G41, Grafik: Gigabyte GTX 1080TI, RAM: 2x 8GB DDR3 (1600), Storage: Samsung SSD 850 Evo
https://linustechtips.com/topic/1020247-stuck-on-1803/#findComment-12183651
On 1/13/2019 at 5:17 AM, Ravendarat said:
It doesn’t let me start it saying it’s because I don’t have the newest windows version
Did you try the manual upgrade tool from Microsoft here: https://download.microsoft.com/download/9/4/E/94E04254-741B-4316-B1DF-8CAEDF2DF16C/Windows10Upgrade9252.exe
I've seen a few systems not being offered the upgrade but with that tool they installed the update just fine.
ASUS ROG Strix SCAR 16 G635LX | Intel Core Ultra 9 275HX | SK Hynix 64GB DDR5-5600 MHz RAM | GeForce RTX 5090 | BOE NE160QDM-NM8 16" QHD+ 240 Hz Mini LED Display + AOC Agon PRO AG274QZM QHD 240 Hz Mini LED IPS 27" Monitor | 2x WD_BLACK SN850X 8TB SSDs (RAID 0) | Intel Wi-Fi 7 BE200 WLAN | Windows 11 Education
https://linustechtips.com/topic/1020247-stuck-on-1803/#findComment-12195595
4 minutes ago, Ravendarat said:
Yep, no go, but thanks for the suggestion.
update all your drivers. all of them. Then try
none should be incompatible but I know windows has blocked things in the past due to old driver versions
"If a Lobster is a fish because it moves by jumping, then a kangaroo is a bird" - Admiral Paulo de Castro Moreira da Silva
"There is nothing more difficult than fixing something that isn't all the way broken yet." - Author Unknown
Intel Core i7-3960X @ 4.6 GHz - Asus P9X79WS/IPMI - 12GB DDR3-1600 quad-channel - EVGA GTX 1080ti SC - Fractal Design Define R5 - 500GB Crucial MX200 - NH-D15 - Logitech G710+ - Mionix Naos 7000 - Sennheiser PC350 w/Topping VX-1
https://linustechtips.com/topic/1020247-stuck-on-1803/#findComment-12196233
