Thermal Grizzly Kryonaut vs IC Graphite Thermal Pad
Solved by Cyberspirit,
As far as I know, the pads are viable but, not for long term use. Use the paste unless you want to replace the pad often.
Sorry, seems like I was wrong about that. Graphine pads should last you longer but, a good quality paste should still perform a little better so if you really can't be bothered to change the paste then, a pad would be a good solution.
Featured Topics
Vectraat ·
Posted in Phones and Tablets0 -
1
superbrett2000 ·
Posted in Cases and Mods4 -
ItzTibby ·
Posted in Cases and Mods1 -
tanjackson ·
Posted in Storage Devices4 -
2
15
