There's 0 reason you should have the aio...for the People that don't know 1/2" hose...there's no excuse in almost 2020 lol
2600x 4.3ghz-Loop
Msi X470 gaming plus
EVGA SuperSC CL16 3200 16gb
gtx 1060
pny nvme 480gb
mushkin eco3 480gb
Sound Blaster Audigy FX
Cooler Master GXII Pro 750w.
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12161938
4 hours ago, Markoff29 said:
I was thinking about upgrading from my cryrig H7 to an AiO,but im not sure if it will fit.
I have trident z memory so im pretty sure i can't top-mount it,but my GPU is 280 in leanght so i was wondering if it would fit in the front?
''Graphics card length limit Max 315mm with front fan mounted''
if you go with a 30mm thick radiator you will have 5mm left over.
so yes it should work fine.
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12162575
WHAT AIO??????????????????????
Seriously, do you expect people to use crystal ball to guess what AIO you want to use?
Sure, most of mainstream ones use super thin radiators, but who knows what kind of jerry ricked solution you plan to use?
Vega 56 Pulse fits with H115i in the front, so I guess you are safe?
But then again, I am not sure if it is safe to assume you can mount a radiator
Ex-EX build: Liquidfy C+... R.I.P.
Ex-build:
Meshify C – sold
Ryzen 5 1600x @4.0 GHz/1.4V – sold
Gigabyte X370 Aorus Gaming K7 – sold
Corsair Vengeance LPX 2x8 GB @3200 Mhz – sold
Alpenfoehn Brocken 3 Black Edition – it's somewhere
Sapphire Vega 56 Pulse – ded
Intel SSD 660p 1TB – sold
be Quiet! Straight Power 11 750w – sold
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12162770
  • 4 weeks later...
I ordered Meshify C TG today. Im going to fit nzxt kraken x62 at front. I have Gigabyte 1080ti thats only 280mm (this should fit without mod). Im going to do that front panel "web" cut mod for better airflow and place fans or rad outside of case. If thats not enough im going to mod that front panel more. I can post pics after this is done and explain what i had to do. I dont want bigger case becaus i dont like huge unused space inside case.
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12264861
kraken radiator is 30mm thick so with your GPU there's no need for removing the web just for airflow, the web doesn't really impact airflow. just an fyi :)
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12265275
I know this. There should be enough room something like I-- GPU ---I 5mm I-- fan--II-- radiator--I case. But i want more space for better airflow inside case so im going to do something like  I-- GPU ---I 35mm I-- fan--I case I-- radiator--I
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12267232
I own an ATX Meshify C you can fit a 120-240mm AIO at the top with (max component height on mobo 40mm) and 120-360mm AIO at the front of the case. And you can fit a 31.5cm GPU with the front fan mounted. If you remove the front fan you'll get an extra 1.5cm of room for the GPU.
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12267374
My case arrived yesterday. There was enough space to front mount Kraken x62 inside. Becaus i had extra set of 140mm fans i did push/pull. Had to modify front panel and also removed that web inside front panel. Also drillet some holes to front panel for 3x140mm fans. If i ever go back to cpu air cooling im going to mount 3x140mm fans to front. Probaply i need to remove front usb if i do that.
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12281241
I have an H100i V2 240mm rad in the top and the 120mm AIO portion of the EVGA Hybrid conversion kit in the rear and can still fit all 3 120mm fan locations up front with ML120's. I have have the regular Trident Z RGB ram and everything clears. there is an order in which you need to install the AIO's, but it will all fit.
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12281505
  • 3 months later...
HI Daniel,
Could you confirm me that you have a Meshify C with 240mm AIO on top and Gskill Trident Z installed?
Could you send a photo?
Thank you ?
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12613862
5 hours ago, Bishaady said:
HI Daniel,
Thank you ?
Hey,
you should be fine on ram clearance with a 240mm radiator in the top, you start running into problems with a 280mm in the top.
if you do a quick search on google pictures:''meshify c top mounted radiator'' you can find a couple picture of builds with the setup you're going for.
hope this helps. here's an example picture: CLICK
take in mind that the h100i is 27mm thick and as some radiator are 30mm thick that might cause an issue, so if you pick an AIO that uses a 27mm thick radiator you should be good to go.
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12614376
Hey,
I PM'd him a picture, even if the rad was thicker as long as it stayed a 240mm I think the trident z would still clear, I did some rough measurement and it looks like the top edge of the heat spreader still has a good 6-8mm before the fan catches the edge of it. this may depend on the exact motherboard being used though as I don't think memory height from the top of the board is a standard, which is why in the PM I specified every part I used, there is always the option of going to a lower profile fan and gain like a half inch of more clearance at the cost of performance.
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-12615688
  • 1 year later...
Hi,
are those front fans 25 mm thick? I am thinking about doing something like this but I need to be sure that I can fit 25 mm fans in front. I don't want some low profile fans.
Do you have more pictures of the mod? How is the noise? Aren't there weird noises when the fans are so close to the front mesh?
Thanks
https://linustechtips.com/topic/1018119-meshify-c-and-aio/#findComment-13981058
