Asus dual 1070 fan speed spikes
Solved by crosstiger,
The fans are most likely dc controlled and don't get enough voltage below 30% to start up properly.
If you want a 0 rpm mode I suggest setting the second "point" in the curve to 36c and set the temp hysteresis to 3c.
proxyyfps ·
Posted in Troubleshooting2 -
Krisp-kiwi ·
1
3
SashaSanguine ·
Posted in Troubleshooting0 -
Artur Hawkwing ·
Posted in Storage Devices6 -
SashaSanguine ·
NekoTheKatze ·
Posted in Troubleshooting1 -
2
