i discovered a brand new pc problem in dec 2018, i dont think anyone has witnessed it before cause i couldnt fix a fix anywhere, so basicly when i shut down my pc, go out/work/whatever, come home and turn back on my pc, it acts as if it was just put in sleep mode, and as soon as i log in all my programs are open from when i shut down my pc. so be on the lookout if u get this brand new pc problem in 2019
possible fix?: im pretty sure it has something to do with ur processor not turning off when everything else turns off, but i wonder why the processor doesnt overheat because the fan is off when i shut down, possible fix could be buying a new processor i have no clue this is my 3rd brand new pc problem i invented in 2018 and i refuse to waste money on something money probably cant even fix.because i guarentee i can buy all new parts and still get same problems...its just my curse
https://linustechtips.com/topic/1017363-new-pc-problem-discovered-alert/
Just turn off the pick up where you left off in Windows and stuff won't open again.
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
