Ram speed?
Solved by Decimator,
That is because your processor supports DDR4 memory only upto 2400MHz, so the system automatically reduces the ram speed to a speed compatible with your processor. Upgrading the processor will help! But there will be no noticeable difference at higher speeds because 2400 MHz is fast enough. Hope I could help!
Check supported ram type at Intel
octester ·
Posted in Troubleshooting1 -
DavidPatrascu ·
Posted in General Discussion5 -
1
2
bill well ·
Posted in Peripherals0 -
4
2
Ha-Satan ·
Posted in Networking3 -
1
Beenlucky1 ·
Posted in Cooling4
play_circle_filled
Latest From ShortCircuit:
