Nickel blocks with copper radiator?
Solved by W-L,
4 minutes ago, IsaacThePooper said:Something like this? https://www.amazon.com/XSPC-Performance-Premix-Coolant-Green/dp/B00AXW07TE
Isn't this the same as anti-corrosion coolants?
Yes that would work and premixes have everything included, biocides, anti-corrosives, coloring if it's dyed.
The XSPC EC 6 series now is a glycerol based product making to compatible for PETG based tubing also. If you are using PETG hardine tubing you want to avoid using glycol based fluids.
Just now, IsaacThePooper said:So would a full copper watercooling kit but just adding a nickel gpu waterblock be fine?
Yes no problems at all.
