USB 3 PCI-E card
Go to solution Solved by mariushm,
Most if not all usb 3 controllers are designed to use a single pci-e lane ... so you'll have either 500 MB/s or ~ 970 MB/s theoretical connection to the chipset / cpu. However, due to arranging data in packets, you'll probably have 5-10% less of that.
At the same time, usb 3.0 theoretical bandwidth is 5 gbps, but the data is sent between devices using 8b/10b encoding, which means for every 8 bits of actual data, you have 2 bits of stuff, so only 80% of 5 gbps is actually theoretically possible, or 4 gbps. Then, the device has to arrange data in packets an there's some limitations about how many packets can be sent, how much size can each data packet be, and each packet has some overhead (framing, signaling etc) ... basically, be happy if you get over 400 MB/s.
So a single pci-e lane is more or less more than enough for a single usb 3.0 used to the maximum.
You'd get slower transfer speeds if you access both usb devices at same time.
Doesn't matter if the actual edge connector on the card is x4 if the controller chip on the card can only use one pci-e lane anyway.
where can i get one of these: https://www.ebay.com/itm/PCI-Express-PCI-E-2-Port-USB-3-0-Front-Panel-19-Pin-Card-Adapter-Converter-Board/253477392142?epid=0&hash=item3b046e0f0e:g:YdIAAOSwgLdaofq8:rk:3:pf:1&frcectupt=true
PCI-E x4 card with 2 internal 19 pin USB 3 connectors
but with at least an x4 connection
1 USB 3 connection can saturate the x1 v2, let alone 4
Main Rig: CPU Intel Xeon X5660 (4.55Ghz @ 1.45v) / MOBO Asus ROG Rampage III Extreme / RAM 16GB Corsair Vengeance LPX1866 MHz / CPU COOLER ID-COOLING Frostflow+ 240 / GPU EVGA Titan X Hybrid (+630 core + 400 memory) / CASE Cooler Master CM 690 II Advanced + transparent side panel / SSD Crucial M550 512GB / PSU Cooler Master Silent Pro Gold 1200W / DISPLAY 1440p monitor / KEYBOARD Topre Realforce RGB / MOUSE Corsair Glaive Aluminum RGB / SOUND Creative Labs. X-Fi SoundBlaster Elite Pro / ROUTER Netgear R9000 X10 Wireless ad / OS Windows 10 Pro / DRIVING WHEEL Logitech G27
Web Server Rig: CPU 2x Intel Xeon X5680 / MOBO Supermicro X8DTL-i / RAM 64GB (2X32GB) SK-Hynix ECC LRDIMMs / CPU COOLER ID-COOLING Frostflow+ 120 + Corsair H50 AIO / GPU MSI GTX 1070 Gaming X (+250core +300 memory) / CASE NZXT Lexa S / SSD Kingston 120GB / HDD 4 x 3TB WD RAID 6 / PSU Enermax MaxRevo 1500W / DISPLAY 900p monitor / KEYBOARD Logitech / MOUSE Logitech
Actually Portable Laptop: HP Spectre x360 15' (Late 2018) / i7-8750H, 16GB RAM, 512GB SSD, GTX 1050Ti MaxQ, 4K Display / KEYBOARD Ducky One 2 Mini / OS Linux Mint 19 Cinnamon / WIRELESS ADAPTER NETGEAR A6210 USB 3.0
Bed Laptop: ASUS VIVOBOOK 15 / i5-8250U, 8GB RAM, 1TB Toshiba HDD, UHD 630, 1080P Display / OS Linux Mint 19 Cinnamon
Backup Rig: CPU Intel Xeon X3470 (4Ghz @ 1.4v) / MOBO MSI P55-GD80 / RAM 16GB HyperX 1600Mhz / CPU COOLER ID-COOLING Frostflow+ 120 / GPU Sapphire R9 270X (+150 core + 200 memory) / CASE Cooler Master Elite 343 SSD Crucial MX150 250GB / PSU Seasonic SS430-GB / KEYBOARD Logitech G910 Orion Spark / MOUSE Logitech / DISPLAY Dell SE2417HGR / OS Windows 10 Pro / WIRELESS ADAPTER
TP-LINK Archer T6E PCI-E
Server 1: DELL POWEREDGE 1950 / 2x Intel Xeon E5450, 16GB ECC, 4x 3TB Western Digital (Various) 7200RPM SATA HDD in RAID 6, GT 640 / DISPLAY Lenovo L2251p
Server 2: DELL POWEREDGE 1950 / 2x Intel Xeon E5420, 8GB ECC, 2 x 160GB SAS, GT 210
https://linustechtips.com/topic/1015073-usb-3-pci-e-card/
https://linustechtips.com/topic/1015073-usb-3-pci-e-card/#findComment-12135808
