Two short beeps and no display pc error
Go to solution Solved by LuckyAsFox,
On 1/13/2019 at 10:07 PM, elon said:
my last bet, your cpu's menory controller has been rekted. that may cause the men error sound. buy a cheap 6th gen cpu to check for it.
Nope. It was all along an unseated graphics card. It seemed like the little click thing that holds the graphics card in the pcie slot was broken. I walked into a computer repair shop and the guy said the beeps was just the computer starting up, not a beep error code .... Sorta triggered right now because i missed something so simple, Oh and the other motherboard I tested it on pcie slot had bent pins. I also didn't realize that there was a hdmi port on the motherboard which I thought was a display port.
At least it's finally fixed now Lol.
Pc Specs
My pc specs
i7 6700k
gtx 970
16gb ram
one hard drive
and one ssd
Manufacturer Acer
Product Predator G6-710
I tried changing the graphics card, ram slots, resetting the cmos, Nothings working.
When did this happen?
Primary PC:
I took out all the parts and put it on a cardboard box to troubleshoot it better. Because I was getting a blue screen and I think my motherboard is the problem, but now I run into this problem
Try running with less ram and no storage, try to get to BIOS.
Primary PC:
Just tried it with one ram stick and the m.2 ssd connected, still having the same problem Although I realize if I don't reset the cmos it doesn't restart and there's no beeps but still a black screen.
Sounds like a display device issue. Try integrated graphics and not graphics card.
Primary PC:
I don't think there are any display ports on the motherboard and I don't think its a display device issue either because it worked fine before
Unplug the m.2 ssd. It could be what's causing the problem. Probably not but it could be. Also make sure that you are plugging your ram into the correct spot. When you have two sticks, use slots 2 and 4.
Build:
Intel Core I7 6700k (clocked to 4.6ghz)
Patriot Viper 3000mhz ddr4
ASUS maximus 8 hero (I hate this mobo)
Evga gtx 1080 superclocked
250GB Samsung 850 evo
2tb WD Black 7200rpm
Ek watercooling kit a240g with 360 expansion pack
Primochill Vue Red fluid
Corsair Graphite 600t (white)
You thought "Gee, Donald Trump sure has a great build!"
I have two sticks of ram, but I'm not sure whats the "correct spot? Do I plug them both in the correct spot or just one?
Try using them both in the second and fourth slots from the cpu. If that doesnt work, plug one stick into the first slot, then the second, and try using the other ram stick. With Acer I believe two short beeps is the code for memory or graphics errors.
Build:
. Tried the second and fourth slot than the first and then tried taking the m.2 didn't work
I do have spare ram but all the other ram won't fit in the socket
Idk what to try after this. maybe try taking the gpu out and seeing if it will still beep.If it doesnt beep, you have a bad gpu. also make sure you have your cpu fan plugged in and the cpu  4 or 8 pin power as well as gpu power. Also, if it was blue screening before, it could have been a corrupt installation of windows or your pc overheating. Since this issue started happening after you took everything apart because of the blue screen, you probably just didn't plug something in right, or not at all. blow out all the sockets you are plugging stuff into with compressed air or with your mouth. just try not to get spit on everything. You didn't happen to spill anything on the pc right?
Build:
Likely not the issue but is your RAM overclocked at all? Or have you set the speed manually in the bios?
I changed the gpu and still the same problem. It only beeps when I reset the cmos, if I don't reset the cmos after I power it down and turn it back up it doesn't beep. I'm pretty sure I didn't spill anything on the pc. I'll try unplugging and replugging everything
The blue screen error I had a whea uncorrectable error that blue screened randomly. I posted the problem on another forum here:http://www.tomshardware.com/forum/id-3835347/whea-uncorrectable-error-find-solution.html#21581605
I haven't touched the ram settings in the bios so I'm assuming the speed is set to manual.
what motherboard is that m8?
Main Rig
CPU: i7 3770K@4.7GHz
GPU: R9 290x 4G
HDD: 12TB Seagate 12TB BarraCuda
SSD: Crucial xm500
RAM: 4 GB DDR3 XPG 1600 x4
Monitor: Dell U2518D
Server
CPU: duo Xeon X5670 stock clock
Motherboard: unknown dell server motherbored
RAM: 64GB of unknown ECC 1600MHz ram
GPU: Nvidia Quadro P4000
HDD: x8 Dell 2.5inch SAS drive in raid, potenal speed of 800MB/s speed
SSD: NON
Case: Dell unknow server case
PSU: duo 700w server powersupply
Works laptop:
Model: Microsoft surface laptop 3
CPU: i5 1065g7
RAM: 8gb lpddr4x
Dongle: satechi aluminum mutiport adapter v2
SSD: 256gb stock
Comment: best laptop on my lap
I suck at writing this.
Try using another monitor/tv and/or cable as you said nothing was happening. Also, Have you by any chance taken the cpu out. If you did, make sure the triangles are aligned correctly .If that doesn't work. you may have bad ram, cpu or motherboard. Ask to borrow a dd4 stick of memory from a friend or get a cheap stick on ebay just for testing.
Build:
haven't taken out the cpu and I have got spare ddr3 ram its just it won't fit in the socket
oem prebuilds?
Main Rig
GPU: R9 290x 4G
SSD: Crucial xm500
Server
SSD: NON
Works laptop:
CPU: i5 1065g7
RAM: 8gb lpddr4x
SSD: 256gb stock
You have a 6700k which requires ddr4 memory. I'm out of ideas. can you give a pic with memory installed and everything hooked up?
Build:
I found some information of that motherboard, its a acer B150-MIB15L, its a B150 with a 6700k :/, isnt your problem, but you could always change your motherboard with a z170/270 if you got the money and if the motherboard is the problem. making most of out of the unlocked cpu
Main Rig
GPU: R9 290x 4G
SSD: Crucial xm500
Server
SSD: NON
Works laptop:
CPU: i5 1065g7
RAM: 8gb lpddr4x
SSD: 256gb stock
Oh my bad. I just looked up the memory model number it is ddr4. I'll send in around an hour because I'm going out somewhere now.
Gr8 m8. Im going to sleep its 2 am here. I'll check back in the morning.
Build:
