replacement parts for akg k7xx
shooter2749
hi,
as you can see on the picture the plastic part is broken and will soon rip off completely
do you know of any place where I can get this part? or at least how its called so I can try to search for one
Yikes, if I were you I would super glue a flexible yet strong sheet of paper or plastic. I would use a dress shirt collar stays, or collar tabs. The thing that you put on to dress shirts collar to help them look more firm. That way you can live a bit longer, you have to replace the whole headband. They're quite pricey, here where I brought mine from. https://www.fullcompass.com/prod/542276-akg-2458m98030-k702-replacement-inner-headband-assembly
"Audiophilia... when you start to hear voices in your head."
