I know it sounds a bit stupid and i'm ok with how my setup looks at the moment but i was wondering if there is a way to change the led color of the asus post code screen ? Anyone did this before ?  Would be nice if it had white lights.
For anyone posting about my fan setup , i know i'm still checking my possibilities with push/pull.
Kind regards.
https://linustechtips.com/topic/1012016-changing-post-code-color-on-a-motherboard/
On 12/24/2018 at 6:05 AM, emosun said:
segmented displays are not rgb so no.
buy and solder in a white segmented display
Hmm ok i'll look some up ! thanks ;)
On 12/24/2018 at 6:06 AM, Cyberspirit said:
Nah, it's only red. You can probably turn it off in the BIOS though.
Nice system btw. :)
Well its not really annoying me that much, its just nitpicking but thanks ! I've just recently "completed" my build.
The thing to remember with this is that soldering on a motherboard is hellish - so much heatsoak into the various layers of copper etc... probably not worth it IMO
Really nice system though buddy :)
I will only ever answer to the best of my ability - there is absolutely no promises that I will be correct. Or helpful. At all.
My toaster:
CPU: Intel Core i5-4670k @ 4.3GHz
Motherboard: Asus Maximus VI Formula
RAM: 16GB Corsair Vengeance DDR3
GPU: Nvidia GeForce GTX770 2GB
Case: Some free Sharkoon case
Storage: Crucial MX500 500GB SSD | Western Digital Blue 1TB
PSU: Corsair HX750
Display(s): Acer framless 24" 1080p thing | Acer 22" 1600x900 thing
Cooling: Corsair H100i AIO | 2 x Corsair LL120 front intakes on radiator | 1 x Corsair LL120 rear exhaust
Keyboard: Steelseries Apex
Mouse: R.A.T 7
Sound: HyperX Cloud II headset | Creative EAX 5.1 speakers
OS: Windows 10 Pro
Yeah i was thinking the same. If i really have to start soldering on it i could easily do more harm than good. Guess i'll just keep it this way. Maybe it's just an excuse to keep changing things on my build since i ran out of things i could upgrade ? Thanks for the compliment tho !
Kind regards.
? nice build man! Are those cables custom sleeved or from a company like Cablemod/Corsair?
I wonder if it's possible to get some kind of film that will filter out the red light from the display? And just tape that over the display...
I’ve just bought some random cable extender kit. I’m going to buy the cable is extenders with the pre-fitted cablecombs soon tho. Thanks for the compliment !
I was wondering the same thing really !
Not possible unfortunately. LEDs emit in a narrow band so there's only red light to start with.
Only way to do so would be replacing it with a different led module. Which is more hassle than is worth.
