I ordered all my parts and waiting until Christmas to unwrap them. I ordered an 'EVGA BR 450 Watt 80+ Bronze Power Supply' off of very.co.uk for about £50. I'm just wondering if it would be compatible with this build:
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor
CPU fan: AMD's stock Wraith fan
Motherboard: MSI - B450 Gaming Plus ATX AM4 Motherboard
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory
Storage: Kingston - A400 120 GB 2.5" Solid State Drive + Seagate - BarraCuda 1 TB 3.5" 7200RPM Internal Hard Drive
GPU: Gigabyte - GeForce GTX 1070 Ti 8 GB Video Card
Case: Gigabyte - GeForce GTX 1070 Ti 8 GB Video Card
Monitor: LG - 27GK750F-B 27.0" 1920x1080 240 Hz Monitor
PSU: EVGA BR 450 Watt 80+ Bronze Power Supply
IM ALSO NOT PLANNING ON SLI OR OVERCLOCKING iN THE FUTURE
https://linustechtips.com/topic/1011111-need-help-with-psu/
If you're referring to the wattage - yes, it's enough; however, it's not the best of PSUs.
Generally, most consumers won't be able to tell the difference between a middle and high-end PSU, but I still recommend upper end due to the lower chance of it damaging components (Although it is quite rare).
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
https://linustechtips.com/topic/1011111-need-help-with-psu/#findComment-12105922
5 minutes ago, seon123 said:
For £50, you'd be much better off getting a Pure Power 11 400W.
Compatible, yes. Recommended, no.
the 450BR uses a double-forward topology which can cause coil whine with high end gpus IIRC
I'm not sure if the pure power 11 is any better, buy at least it has been reviewed and it is also more efficient and has a longer warranty
https://linustechtips.com/topic/1011111-need-help-with-psu/#findComment-12105931
No reviews and a very low temperature rating is not good signs.
https://linustechtips.com/topic/1011111-need-help-with-psu/#findComment-12105946
Would this be better?
EVGA Power Supply EVGA 650W BQ 80+ BRONZE Power Supply
https://linustechtips.com/topic/1011111-need-help-with-psu/#findComment-12105951
that's why I said pure power 11 seems much superior on paper
but I think that 450BR could be at worst an EVGA 450B with DC-DC
which is not that great but it's not too bad either.
https://linustechtips.com/topic/1011111-need-help-with-psu/#findComment-12106021
With PSUs, it's often best to operate with crap until proven otherwise.
https://linustechtips.com/topic/1011111-need-help-with-psu/#findComment-12106022
Why are you so hellbent on getting a rather shitty EVGA PSU?!
And why such cheap shit?!
You were recommended  good value PSU, why not go with that?!
WHy always look for other stuff, when the one you choose already was pretty bad...
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1011111-need-help-with-psu/#findComment-12107144
