Hey everyone so i need a pc sense I do not have one and I am wondering if I should go with a pre build from like ibuypower or cyberpower and do their monthly payments or just build one myself when I get enough money to do so. Money has been tight I am the only one working right now and am paying all the bills so I am wondering which one is a better option for me thanks
https://linustechtips.com/topic/1010883-pre-build-or-self-build/
Never use financing options unless you need the item immediately, like if your fridge breaks or something
Consensus of the forum is that you should definitely build yourself. Its much cheaper.
Definitely build it yourself, you'll likely get way more bang for your buck. I'd also wait for CES to be over, see what's coming down the pipeline. AMD is supposed to have some pretty big announcements. I'd also look at the used market if you're on a tight budget; you can definitely find some killer deals.
I'm not as anti-financing as others, however there would be many aspects you'd have to look at, including your interest rate.
Eh, it's not so bad, and makes sense if someone just can't afford to save the money all at once. It really only depends on the interest rates; if it's low, or 0% (I'm not sure what theirs is), then there's no downside.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Oh definitely, its not the worst thing in the world, glad it is an option. Though most SI's have an IR between 15-30(?)% I believe. I just can't justify paying that much on top of say a 1000$+ machine
2 minutes ago, dizmo said:
Main And Only Build : CPU : Ryzen 5 1600x (OC to 4.2GHz), Cooler : Thermaltake Floe Riing RGB 240 TT Premium Edition, Motherboard : Asus ROG Strix B450-F Gaming, RAM : Trident Z RGB 16GB (2*8) 3000Mhz DDR4, GPU : Gigabyte Gaming GTX 1070 TI, PSU : EVGA G3 650W 80+ Gold Certified, Storage : 250GB Samsung 860 Evo + 256GB SU800 + 2TB Seagate HDD.
