Is there a way to manually set my CPU clockspeed without messing with voltage?
Or is there a way to get turbo boost to do what it seems it's suppose to do?
i5-6402p
MSI B150M Bazooka Plus
Cryorig C7
When I set the max processor state to 99%, it clocks it to 2.7 GHz(0.1 GHz lower than normal clock speed) in Windows and while gaming.
It won't go above 2.7 GHz because it is set to the max processor state of 99%.
When I set the max processor state to 100%, it clocks it to 3.2 GHz(max turbo boost in 4 core games) and 3.4 GHz in Windows or 1-2 core games.
I have turbo boost enabled but it seems all that does is force the CPU to run at 3.2 GHz while gaming and never go below or above that. I'm thinking the power plan has something to do with this.
Ideally, I'd like the CPU to operate at the 2.8 GHz it's supposed to and go up to 3.2 GHz when needed but apparently that's not how turbo boost works or I have something set up wrong somewhere. Possibly that power plan.
I feel that it's possible to get my CPU to operate at 2.8 GHz by disabling turbo boost and then when I set the max processor state to 100%, it would then operate at 2.8 GHz. But that would mean it will not turbo boost to 3.2 GHz when needed(not that I ever see it do that in the first place when it's enabled because of the 99% setting).
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/
.......... Why?
Turbo boost isn't an "always on" thing. It depends on TDP, settings in bios, temp, etc. There are also things called C-states which allow the processor to downclock when it's not being used.
Turbo boost also isn't an "all core" thing. It's typically only 1 core.
You could disable energy saving C-states and your cpu would always run at 2.8 GHz and boost up when needed, although that'd waste energy.
What.... exactly are you trying to accomplish here?
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12097257
What settings in BIOS? And how does temp factor in to turbo boost?
Type - CPU / Microprocessor
Market segment - Desktop
Family - Intel Core i5
Model number - i5-6402P
Frequency - 2800 MHz
Maximum turbo frequency - 3400 MHz (1 or 2 cores), 3300 MHz (3 cores), 3200 MHz (4 cores)
http://www.cpu-world.com/CPUs/Core_i5/Intel-Core i5 i5-6402P.html
How do I do that? I had my CPU run at 2.7 GHz at all times for 2 years without energy bill issues.
Is there a way to manually set my CPU clockspeed without messing with voltage? Instead of 2.7(cool as can be yet under-performing) or 3.2(hot yet performing at max potential), I'm looking for 2.8 or 2.9 or 3.0(I feel one of these is a sweet spot). Why? Because of what you see in parenthesis.
Obviously a better cooler would be my best bet and just game at 3.2 but I love my cooler. I just got it and it does it's job better than stock did and I feel it would do an even better job at a sweet spot GHz.
Or... is there a way to get turbo boost to do what it seems it's suppose to do?
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12097286
Go into your BIOS and adjust your CPU multiplier to your max boost speed 3.2Ghz, but on all cores.
Go and disable boost (since you're locking it to boost speeds) , but keep c-states enabled so your PC downclocks when doing non-intensive tasks (browsing internet, youtube, etc)
My rig:
CPU: Ryzen 7 5800x
MB: Gigabyte B450 I Aorus Pro WiFi
RAM: Kingston Fury Beast RGB 32GB (2x16GB) 3600mhz CL16 (1-to-1 Infinity Fabric enabled)
GPU: Gigabyte RTX 2080 Super
*bought for $200 CAD off a friend who needed an RTX 3080, price was my reward.
CASE: InWinn A1 Plus in White with included 600w gold sfx PSU and included custom length cables
DISPLAY: 3x 20" AOC 1080p 60hz 4ms ,  32" RCA 1080p/60hz TV mounted above, all on a single arm.
Storage: C : 1TB WD Blue NVMe      D : 2TB Barracuda      E: 240GB Kingston V300 (scratch drive)
NAS: 240GB Kingston A400 + 6x 10+ year old 700GB Barracuda drives in my old FX8350+8GB DDR3 system
Logitech G15 1st Gen + Logitech G602 Wireless
Steam Controller +  Elite Series 2 controller + Logitech G29 Racing Wheel + Wingman Extreme Digital 3D Flight Stick
Sennheiser HD 4.40 Headphones + Pixel Buds 2 + Logitech Z213 2.1 Speakers
My Girlfriends Weeb-Ass Rig:
Razer Blade Pro 17 2020
10th Gen i7 10875H 8c/16t @5.1ghz
17.3" 1080p 300Hz 100% sRGB, factory calibrated, 6mm bezel
RTX 2070 Max-Q 8GB
512GB generic NVMe
16GB (2x8GB) DDR4 3200Mhz
Wireless-AX201 (802.11a/b/g/n/ac/ax), Bluetooth® 5.1, 2.5Gbit Ethernet
70.5 Whr Battery
Razer Huntsman Quartz, Razer Balistic Quartz, Razer Kraken Quartz Kitty Heaphones
*deep breath*
Razer Raptor 27" monitor, IT'S BEAUTIFUL.
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12097289
Where do I do this exactly? I know how to get into the BIOS but any idea of which tabs to look under?
I know how to disable turbo boost. I figured to keep c-states enabled(whatever they actually are). They sounded important.
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12097293
I don't think you can overclock with the multiplier on your b150m motherboard, or even overclock your CPU. I'm pretty sure you can do some BLCK stuff but you need a Z170 motherboard for that.
Usually Intel has certain chipsets for OC's and unlocked cpu's for OC's. For all the 14nm CPU's its been Z motherboards and all core cpu's its had the K at the end.
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12097327
Then I think my only option is to get turbo boost to function correctly. It seems my power plan is not letting it work like I want it to. When I set my max processor state to 99%, it then won't ever go over 2.7 GHz. And when I set it to 100%, it then stays at 3.2 GHz.
What do I set my power plan at and what do I set the min and max processor state to in order for it to start at around 2.7-2.8 GHz and go up to 3.2 GHz when needed? Isn't that what turbo boost is supposed to do?
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12097336
You know now that I think about it, I think this is what my PC is doing. It's supposed to sit somewhere at 3.? ghz but it stays at 3.9ghz turbo. I honestly don't know what could be causing this, maybe something is wrong with the power delivery on your motherboard?
8086k
aorus pro z390
evga 3070 ultra
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12097341
17 minutes ago, A Random Dude said:
It's grayed out.
It's on all cores by default.
Is base clock not grayed out?
I did a quick google for "MSI B150M Boverclocking" and I found that it doesn't have multiplier overclocking, but it should have baseclock (which changes the frequency of the whole motherboard, not just the CPU)
If baseclock is there, great. Push it until you hit the 3.2Ghz minimum you're looking for. If it boots, great! Go back and try 3.4Ghz.
If it doesn't, lower your ram speed as changing the baseclock also changes the frequency of your ram.
Same goes for if it does boot and it doesn't when trying 3.4Ghz.  Just lower the ram speed. Then you should boot just fine.
Overclocking is a lottery, but a good rule is that /every/ intel chip will overclock to their max turbo speed on all cores & at the stock voltage absolutely fine. Just make sure you have adequate cooling and you're good to go!
A stress test at 3.4Ghz wouldn't be a bad idea to make sure your cooling and 3 year old CPU are upto the task :)
Edit: Intel spec sheet says max turbo is 3.4Ghz, just push the base clock until you hit that and lower your ram speed if you run into any problems along the way.
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12097378
Wait, hold on. I didn't notice you have a P series processor.
They're not meant to be overclocked at all. Disable c-state, your PC will munch more power but it'll remain at the max frequency.
http://www.tomshardware.com/answers/id-3126377/6402p-clocked.html
My rig:
CPU: Ryzen 7 5800x
RTX 2070 Max-Q 8GB
512GB generic NVMe
70.5 Whr Battery
*deep breath*
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12097387
Nothing is wrong with the power delivery of the motherboard. What's causing it is the power plan. When you set the max processor state to 99%, it never goes over your base clock speed. When you set the max processor state to 100%(where yours is currently at probably, go check), it clocks your CPU at max turbo boost. Which is fine if you have an awesome cooler. I just bought my cooler to be better than stock cooling which would work great if I can figure out how to clock my CPU to 3.0 GHz.
I can already do this just by setting my max processor state to 100%. It then runs 4 core games at 3.2 GHz and 1-2 core games and Windows at 3.4 GHz. And as I explained, my cooler isn't the greatest to allow 3.2 GHz gaming for more than around 90 minutes. At least from my testing so far. It basically starts to get hot around the hour mark and game in the 60 degrees just fine but I want it in the 50's like I've always had it. 71 degrees is my max CPU temp. This is the first time in 2 years that my CPU has hit 60 degrees. Which is completely understandable now that my CPU is running at a constant 3.2 GHz.
Right now I'm stuck between gaming at 2.7 GHz(keeping turbo boost enabled and setting max pro speed at 99%), 2.8 GHz(disabling turbo boost and settings max pro speed at 100%) or 3.2 GHz(keeping turbo boost enabled and setting max pro speed at 100%). I want it to do what it's designed to do. Clock at 2.8 GHz and boost to 3.2 GHz when needed. My power plan does not allow it unless I can figure out how to set it a certain way. I'm missing something there. I feel that someone knows exactly what setting I'm looking for.
I just figured all this out yesterday. Exactly two years after I've been gaming at the 2.7 GHz it has always been set at. I never used to notice because I didn't used to monitor my CPU clock speed while gaming. I added that to my MSI AB monitoring like a week ago. I then noticed the 2708 MHz never change after playing multiple games and was like, why isn't it turbo boosting? It's because of that power plan max processor state.
https://linustechtips.com/topic/1010135-cpu-clock-speed-issue/#findComment-12098841
