Cooler for Ryzen 2600
Maidere
Hello, guys! I need an advice. Recently I've bought a new PC, and I chose Ryzen 2600 as a CPU for it. For cooling purposes, I picked Deepcool GAMMAXX 200, and when I'm putting all cores under 100% load (what I'll have to do) CPU's temp goes up to 80 degrees Celsius.
I need a, preferably not expensive, cooler that will be able to keep my CPU within reasonable temps under 100% load during the long rendering sessions.
Motherboard: ASRock B450 Pro4
Thank you!
Why not just use the stock cooler?
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
The stock cooler is enough unless you have REALLY bad airflow, like 1 fan, and so on. Those temps don't sound right at all.
I also have the 2600, I went with the Dark Rock Pro 4 and under 100% load it sits around 65 to 70 max, it's also really silent.
(I think, I'm not sure if I'm confusing the temps with the GPU stress test)
It's OEM and no, stock cooler is roughly equal the one I've got, so it will go up to 78-80 under 100% load easily.
AMD pulled an Intel with the stock cooler on this one. It wont run it at full turbo without reducing clocks with that. Does the '200 run stock CPU settings at 3.9 under sustained load?
I'm running a Noctua D9L because I had it spare, but needed separate AM4 kit I think. So not a suggestion but gives a ball park indication of what works and will even allow a manual OC to around 4.2 all cores.
Gaming system: R7 7800X3D, Asus ROG Strix B650E-F Gaming Wifi, Thermalright Phantom Spirit 120 SE ARGB, Corsair Vengeance 2x 32GB 6000C30, RTX 4070, MSI MPG A850G, Fractal Design North, Samsung 990 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
Productivity system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, 64GB ram (mixed), RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, random 1080p + 720p displays.
I think it was on purpose because they had to make people buy the 2600x somehow...
but i digress
I'm kind of torn between Cooler Master Hyper 212 LED Turbo and Cryorig H7 and will likely go with the former since it comes AM4 compatible right out of the box and I won't even need to take the goddamn MB out of the case.
I have a 2600x with a Evo 212 and get temp at 100% load at 62c CPU Stress test and 100% load at 75c using FPS Stess test
am upgrading to liquid cooler Masterliquid ML240R RGB to get better Temps
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
Did you OC it? 62c sounds reasonable tbh, I do not expect to have anything much better.
@Maidere did you overclock? did you change voltage?
its quite possible bios auto voltage pumps way too much, causing the temperatures
MSI GX660 + i7 920XM @ 2.8GHz + GTX 970M + Samsung SSD 830 256GB
Just checked, in AIDA64 stability test voltage is around 1.2V, looks reasonable to me. Temps go high tho.
The most I’ve overclocked there’s 4.5 GHz it was kinda stable but the temps where high in the 80s and idle was at 50c but the brought down to stock since it works perfectly at 4.2
My PC:
My Kids PC:
Just buy a dark rock 4 or the pro 4 and use it to get great temps or get Liquid cooler
My PC:
My Kids PC:
Unless it's old stock, the H7 should also come with AM4.
What case and ram are you using? Where are you shopping / located?
CRYORIG m9a
Case: Zalman N2,
RAM: HyperX Fury 2933 16 GB (8+8).
Now I'm thinking between Cryorig and Scythe Mugen 5, the latter is praised on our local forums as one of the best value coolers for AM4 platform.
I'm located in Moscow, Russia.
An Arctic Freezer 33 eSports ONE
CPU: Core i9 12900K || CPU COOLER : Corsair H100i Pro XT || MOBO : ASUS Prime Z690 PLUS D4 || GPU: PowerColor RX 6800XT Red Dragon || RAM: 4x8GB Corsair Vengeance (3200) || SSDs: Samsung 970 Evo 250GB (Boot), Crucial P2 1TB, Crucial MX500 1TB (x2), Samsung 850 EVO 1TB || PSU: Corsair RM850 || CASE: Fractal Design Meshify C Mini || MONITOR: Acer Predator X34A (1440p 100hz), HP 27yh (1080p 60hz) || KEYBOARD: GameSir GK300 || MOUSE: Logitech G502 Hero || AUDIO: Bose QC35 II || CASE FANS : 2x Corsair ML140, 1x BeQuiet SilentWings 3 120 ||
LAPTOP: Dell XPS 15 7590
TABLET: iPad Pro
PHONE: Galaxy S9
She/they
