Posted January 11, 2014 Hi guys, What do you guys think about these 2 coolants? (the İce Dragon is 1/4 the price of mayhems...) http://www.frozencpu.com/products/15033/ex-liq-203/Ice_Dragon_Cooling_Nanofluid_Coolant_White_Color_-_32oz.html http://www.frozencpu.com/products/17707/ex-liq-284/Mayhems_Pastel_Coolant_Concentrate_-_250mL_-_Ice_White.html?tl=g30c337s1809#blank Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 I prefer mayhems one, ive not used the other one, honestly i dont have much experience with custom loops so i doubt im a trustworthy source. cpu: intel i5 4670k @ 4.5ghz Ram: G skill ares 2x4gb 2166mhz cl10 Gpu: GTX 680 liquid cooled cpu cooler: Raijintek ereboss Mobo: gigabyte z87x ud5h psu: cm gx650 bronze Case: Zalman Z9 plus Listen if you care. Cpu: intel i7 4770k @ 4.2ghz Ram: G skill ripjaws 2x4gb Gpu: nvidia gtx 970 cpu cooler: akasa venom voodoo Mobo: G1.Sniper Z6 Psu: XFX proseries 650w Case: Zalman H1 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 I'd go with mayhems coolant, I've never heard of ice dragon before Please become a member of the Linus Tech Tips forum, keep writing smug remarks & let us love you. Peace out. <| Project M13 & Silverstream. Other DIY projects |> Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 Author I'd go with mayhems coolant, I've never heard of ice dragon before İce Dragon and Mayhems worked together to create mayhems pastel series of coolants Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 i say go with whomever is cheapest Cpu: Intel i7 4770k @4.4 Ghz | Case: Corsair 350D | Motherbord: Z87 Gryphon | Ram: dominator platinum 4X4 1866 | Video Card: SLI GTX 980 Ti | Power Supply: Seasonic 1000 platinum | Monitor: ACER XB270HU | Keyboard: RK-9100 | Mouse: R.A.T. 7 | Headset : HD 8 DJ | Watercooled Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 IMO mayhem pastel looks incredible with good lighting. The colour is opaque so it looks like as if you've used a colour tubing. If you're going for aesthetics then mayhem pastel is the one to go. Ice dragon fluid is expensive because it lasts longer in your loop. Either is a good coolant to use. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 Author IMO mayhem pastel looks incredible with good lighting. The colour is opaque so it looks like as if you've used a colour tubing. If you're going for aesthetics then mayhem pastel is the one to go. Ice dragon fluid is expensive because it lasts longer in your loop. Either is a good coolant to use. No, you can buy 1lt of ice dragon fir the price of a 250ml mayhems, mayhems is much more expensive. The lighting in my system is a NZXT Hue so it is pretty good i wonder if mayhems will make a noticeable diffrence because i care about looks alot and willing to spend more on better looks but i dont want to waste money too. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 That 250ml of Mayhems is a concentrate that gives you 1 liter with 750ml of distilled water. So unless distilled water is expensive where you are from, the Mayhems is cheaper. Sponsored Build log (In Progress): The Utterly Imbalanced CaseLabs TX10-D build(s)! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 Double post. Sponsored Build log (In Progress): The Utterly Imbalanced CaseLabs TX10-D build(s)! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 Author That 250ml of Mayhems is a concentrate that gives you 1 liter with 750ml of distilled water. So unless distilled water is expensive where you are from, the Mayhems is cheaper. Ohh i didnt know that i ve read a lot of good things about mayhems so if the price is equal i will pick mayhems anyday should i get the mayhems h20 water to go with it? And also how much water do i use with that 250ml mayhems i linked? (like is it 3ml to 1ml which would equal 250 to 750 = 1lt) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 11, 2014 If you have easy, inexpensive access to distilled water then just buy that- no need for fancy pure water. It is a 1:3 ratio of pastel concentrate to water as mentioned on the product page. Sponsored Build log (In Progress): The Utterly Imbalanced CaseLabs TX10-D build(s)! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2014 Ice dragon really comes into the frey at higher temps, I have tried Mayhems variant as mayhems and ice dragon are partners. I'd stick with pastel mate. Core - EVGA Classified 3 | i7 980x | 12GB Corsair Dominator GT | Lian Li P80 | Corsair 128 Neutron GTX | 2 x WD 500gb Velociraptor | Asus Xonar Xense | 2 x EVGA 590 | Enermax Platimax 1500 Water Cooling - Alphacool NexXxos 360 Monsta | TFC 360 | Alphacool D5 Vario | Alphacool 250 Tube res | EK Supreme HF Nickle Plexi | 2 x EK Nickle Plexi 590 WB | Aquaero 5 XT Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2014 Author Ok, thanks alot guys mayhems is it then Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2014 Author If you have easy, inexpensive access to distilled water then just buy that- no need for fancy pure water. It is a 1:3 ratio of pastel concentrate to water as mentioned on the product page. can i use the water i drink? i am still alive so it should be distilled enough? but i really dont want to risk it D: can i use that Mayhems H20 water? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 12, 2014 You can use the mayhems water, it's just distilled water that has been filtered extra times. Do not use mineral or tap water. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2014 Author You can use the mayhems water, it's just distilled water that has been filtered extra times. Do not use mineral or tap water. tap water Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2014 Distilled water at walmart here is like 88 cents for a gallon Intel i5 6600k~Asus Maximus VIII Hero~G.Skill Ripjaws 4 Series 8GB DDR4-3200 CL-16~Sapphire Radeon R9 Fury Tri-X~Phanteks Enthoo Pro M~Sandisk Extreme Pro 480GB~SeaSonic Snow Silent 750~BenQ XL2730Z QHD 144Hz FreeSync~Cooler Master Seidon 240M~Varmilo VA87M (Cherry MX Brown)~Corsair Vengeance M95~Oppo PM-3~Windows 10 Pro~http://pcpartpicker.com/p/ynmBnQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2014 Author Distilled water at walmart here is like 88 cents for a gallon i just found 1Lt's of ready-to-use (i hope they are ready-to-use) Mayhems http://www.overclockers.co.uk/showproduct.php?prodid=WC-014-MH Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2014 Thats the one you want Mr Duck, also try specialtech.co.uk, they are by far my first choice for watercooling products in the UK Core - EVGA Classified 3 | i7 980x | 12GB Corsair Dominator GT | Lian Li P80 | Corsair 128 Neutron GTX | 2 x WD 500gb Velociraptor | Asus Xonar Xense | 2 x EVGA 590 | Enermax Platimax 1500 Water Cooling - Alphacool NexXxos 360 Monsta | TFC 360 | Alphacool D5 Vario | Alphacool 250 Tube res | EK Supreme HF Nickle Plexi | 2 x EK Nickle Plexi 590 WB | Aquaero 5 XT Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 13, 2014 Author Thats the one you want Mr Duck, also try specialtech.co.uk, they are by far my first choice for watercooling products in the UK ok thanks Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
