Does this network diagram seem feasible?
Its a bit rough, I am wanting to create a second LAN and give internet access but not allowing it to interrupt anything within the first LAN.  I guess I isolate the link connection between each router as a different IP address to each LAN per each port?
https://linustechtips.com/topic/1006587-network-review/
So long as the firewall/router allows you to segment off the second subnet from talking to the first network you'll be fine, no need to go all out with pfSense.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/1006587-network-review/#findComment-12064515
Okay, Thank you will have a go and see if i can get something working.
https://linustechtips.com/topic/1006587-network-review/#findComment-12064730
The problem you are going to have is you are creating a double nat for the second network and also since the second network is having to use a lan port for connectivity on your first router... that means the devices on network 2 can access ones on network 1.
I mean if you are comfortable with configuring the machines on a double nat if needed you could add a 3rd routers.
Here is my drawing with the crappiest free online software ever!
https://linustechtips.com/topic/1006587-network-review/#findComment-12064908
