Yes. The PSU is an ATX unit with a length of 14cm and the case can take ATX PSU's up to 18cm in length.
https://linustechtips.com/topic/1006184-psu-and-case-apply/#findComment-12060947
2 minutes ago, Brandon Knibbs said:
Yes, however I do suggest you upgrade your PSU if you are changing the other components in your rig
Full Specs
Helios EVO (Main):
Pacific Spirit XT - Server
Delta - Laptop
https://linustechtips.com/topic/1006184-psu-and-case-apply/#findComment-12060948
