what b350 board did you actually choose?
Among B450s, Asrock Pro4 and MSI Bazooka/Gaming Plus will do
Desktop benching:
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057640
8 minutes ago, eliott119 said:
Check the list I just posted, apologies
If cheap is what you want then sure, but pairing expensive fancy RAM sticks and cooler with an oudated group regulated PSU is not what I would have done.
Desktop benching:
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057700
I'm not sure I understand what you mean, you're saying you think its a bad idea to be pairing the RAM and cooler I've chosen with the PSU from my old build? Why would that be?
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057707
Most motherboards you'll buy NOW will come from the factory with one of the latest BIOSes that will include support for Ryzen 2600.
Unless that motherboard sat on shelves for half a year or so (extremely unlikely), you'll be absolutely fine.
Version 4.50 for that Asrock AB350M was published in early March 2018, so it would be safe to say that starting from  May-June, all motherboards received by stores would have this BIOS already.
So if you like that board and the price, feel safe and free to buy it.
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057712
Wrong distribution of budget
Desktop benching:
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057720
Right okay, I think I'll stick with the original MB then and hope that it's been updated to the new BIOS. Many thanks for your help!
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057729
4 minutes ago, eliott119 said:
You're not really explaining, are you saying you think I've wrongly distributed my budget in regards to the RAM and cooler?
I just feel there's a need for replacing the PSU, but you instead used that money to get flashy stuff.
Desktop benching:
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057734
If the pcpartpicker list is what you plan to buy, I'll have to agree with Jurrunio.
You're killing a lot of money on the case, for example .... it's very subjective, personally I like my systems all black or with shades of gray at most, maybe you like RGB a lot... still, you would find great cases at less than 100 pounds.
Should shift a bit of money towards the power supply, best to get something with gold efficiency, and you could also shift a few pounds to motherboard. I'd get something with 4 memory slots, usb type c on the back, maybe usb 3 10gbps on back etc
You could save a few pounds by going with 3000 Mhz memory ... 3000 vs 3200 ... you won't feel the drop in frequency.
It would really help to know for sure what you already have and what you want to buy, I'd like to give you some feedback
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057745
Firstly, thanks for being willing to help me out here :)
Really looking for a white matx case to make as RGB as possible, I like the tempered glass on the Corsair one which is why I chose it. Any alternatives you might suggest?
I mean the PSU I've had has always done me good, so I didn't think there'd be any point in upgrading it at all if I'm being honest
As for the MB I heard its VRMs might be an issue if I'm looking to overclock but I'm not looking for that, I'm also not really interested in moving up to 32GB RAM so the memory slots aren't an issue
I believe going to 3000 from 3200 with the RAM I've chosen only saves me like £3, I've already upgraded the CPU from a 1600 to a 2600 and the SSD from a 120gb to a 240gb, so I've already increased its budget as high as it can really go. An extra £20 for a sweet MB would be nice but I can't afford it on top of the upgrades I've already made
I already have the 970 and the CX 600M PSU, everything else I'm looking to buy - thoughts?
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057764
Just now, eliott119 said:
Right okay I understand now, so what do you think is wrong with my current PSU?
the voltage rails are group regulated. In modern systems which strain the 12V rail a lot more than the 5v and 3.3v rails it's much easier to kick the voltages of these units out of whack.
Desktop benching:
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057776
Right okay, bit out of my depth on that but what does that essentially mean? Are you saying the PSU will eventually just stop working in a year or something, so I should upgrade to a more modern one now to avoid this?
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057786
Plus it's not really 600w , it can output 560w on 12v provided the ambient temperature doesn't go above 30c .... when ambient goes up, you kinda have to derate that psu to maybe 450w on 12v
Luckily it's still enough for that system ... your GTX 970 will consume up to around 180 watts and your 2600 won't go over around 120 watts ... so the whole system will pull 300-350w on 12v when gaming... but with poor efficiency and maybe with a noisy fan.
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057798
Thanks for clearing that up, not stressed on if it's the most power efficient or whatever. I replied to your previous post btw :)
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057829
essentially means it's a thing you should get rid of when you have the money (which you clarely have)
Desktop benching:
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12057833
9 minutes ago, eliott119 said:
So whats the downside if I chose to not get rid of it? Whats going to end up happening/being a problem?
longevity, Just like eating junk food for life. Also no guarantees on what will happen if accidents happen
If you ask me to build something
RGB air cooler to save some cost, not like Ryzen 5 2600 needs more cooling
Motherboard with RGB lights without costing too much
RGB memory stick that's cheaper
DRAM-less SSD like the A400 are slower than those with DRAM like the MX500, while 500GB SSDs are better value than ~250gb ones.
RGB case that's not too expensive
PSU that's good enough by today's standard
full set of RGB fans and RGB controller (connects to motherboard's specific connector)
Desktop benching:
https://linustechtips.com/topic/1005763-motherboard-advice/#findComment-12058000
