Hey everyone. I'm planning my first cooling loop and thus purchased an ekwb ga x370 monoblock which fits all of gigabyte's mainstream x370 boards if not all of their x370 boards. I noticed the VRMs are in similar positions and the only visible difference is the addition of a couple extra pieces up top. The cold plate that makes contact with the top VRM is 7.5 cm wide. Is there some way to measure if this would fit on one of the updated x470 boards?
https://linustechtips.com/topic/1005413-will-my-monoblock-upgrade/
the VRM is placed diffrently on the X470 board than on the X370 board so i doubt the monoblock will go on, at least not right
Builds:
