straight to the point, i have a H150i Pro liquid cooler and a i9-9900k and it struggles to get idle (1-5%) under 40 degrees C i'm not 100% sure but to me that's a bit high for idle, playing gta 5 it only gets to about 30% - 40% usage and about 60 degrees C all 3 fans are on 1500RPM and the pump is 2700ish RPM. the case is the fractal define R6 and the Rad is mounted on the top with the fans pushing air out the top and the thermal paste is stock. i have heard things about the CPU lids not being flat preventing bad contact, and in order to rectify i would have to sand it, that is my worst case scenario. any other thoughts? thanks
System 1        System 2
Intel core 2 Duo T5800 @2.00GHz                                                    Intel core i5-4460 @3.20GHz quad core
4gb RAM        8gb Samsung DDR3 1600Mhz
ATI Mobility Radeon HD 3470                                                            Nvidia Geforce GTX 660 2gb
Windows vista Home premium 32-Bit                                                Windows 7 home premium 64-Bit
(Laptop)        Asrock H81m DGS Micro ATX
System 3        System 4
Intel core i7 6700HQ up to 3.5GHz 6MB Cache                                Intel core i7 6700k @4.20GHz
Nvidia Geforce GTX 970M 3gb                                                          32gb DDR4 G.Skill ripjaws 2233Mhz
Samsung 256GB M.2 NGFF Solid State Drive                                  Gigabyte G1 Geforce GTX 980Ti
1TB 5400RPM Hard Drive        Corsair RM-750 750W 80+ Gold
16GB Dual Channel DDR3L at 2133MHz                                          Gigabyte H170 HD3 LGA1151
15.6 inch FHD (1920 x 1080) IPS Anti-Glare 220-nits Display           Intel SSD 535 Series 240GB
Windows 10 Pro        SanDisk 120GB SSD Plus
8-cell Lithium Ion (92 Whr) Battery                                                     Windows 8.1 Pro 64Bit
(Laptop)        IN-WIN GRone ATX Full Tower
        4g Arctic Cooling MX-2
        Coolermaster Hyper 103
        TP-Link TL-WN881ND
https://linustechtips.com/topic/1004325-i9-9900k-temps/
only way to know if you need to LAP the IHS is to take the chip out clean it up and spin it on a flat surface. If it spins like a top, then it needs to be LAP'd. if it stops almost immediately, then its good.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12044486
1 minute ago, LukeSavenije said:
well, the 9900k is a hot cpu. temps seem fine to me
thats a relief to hear lol.
Thats a good idea i'll give that a crack when i get a chance next, i will also apply some nicer thermal paste while i'm at it.
System 1        System 2
System 3        System 4
        TP-Link TL-WN881ND
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12044488
those temps seem perfectly fine
i7 4790K | 4.5ghz @1.19v / 1080 ti strix oc  / Asus Z97 Pro Gamer  / 970 Evo 500GB | 850 Evo 500GB / Corsair 780t white|window
        PG279Q | VG248QE/ Corsair ax860i   /   Corsair H110i GTX   /  Corsair Vengeance Pro 16GB 2400mhz /
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12044498
Wicked, the last thing id want to is damage and expensive chip like that :/
but if it doesn't ring any alarm bells i shall set and forget, till it needs the dust blown off of it lol
System 1        System 2
System 3        System 4
        TP-Link TL-WN881ND
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12044507
well, everything under 80 degrees is fine imo.
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12044511
12 minutes ago, J-Dogg said:
are u running an offset, what freq is the cpu running at idle, with an offset it should run at 0.6v 800mhz and idles at slightly higher than room temp.
The temp situation is overblown due to premature bios....and running prime fft (no need for that), anything under 85C is fine, the worst gaming probably won't surpass cinebench/blender temps.
It takes a bit of tuning but the 9900k thermals are better than a 8700k thats not delidded, went from not being able to hit 5ghz to ppl running 1.4v 5.2 just for gaming lol.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12044512
it appears to be idling at 4.6Ghz and 1.2V- 1.3V which i agree is unnecessary just to sit on the dekstop... should i do something about this? and is the fix a windows or bios one?
Edit - Motherboard is a Gigabyte Z390 Arorus Pro Wifi and i haven't done any bios updates to it.
System 1        System 2
System 3        System 4
        TP-Link TL-WN881ND
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12044543
bios, if you havent overclocked at all, just change your voltage mode from manual/auto to offset.
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12044546
i wasn't able to do this as i'm too inexperienced to understand the vast amount of settings available on my motherboards bios, i might get in contact with gigabyte themselves or continue to research this as i find the time.
System 1        System 2
System 3        System 4
        TP-Link TL-WN881ND
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12044579
Actually, this seems a bit odd too me. I am also running the 9900K, in a corsair Carbide275R, a slightly smaller case than the R6 (I have the R5 too). With the side panels on, and on stock speeds with the smaller H115i Pro (on full speed pump and fans), I am getting just 30°C on idle, dipping below the 30° occasionally.
I am actually quite happy with these temps, I get to about 77°C with no OC in Cinebench (after 5 consecutive runs), on full speed fans.
However, I am extremely surprised at power draw with undervolting and underclocking the chip. I am getting 58° with a power draw of 115W on 4,5Ghz on all 8 cores.
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12054473
okay. good to know. haven't really kept up with 9th gen tbh. a couple days I fully understanded the z390 boards. thanks for the reply
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12054484
when i set windows power mode to balanced and closed google chrome the clock speed goes from a solid 4.6Ghz to under 2.8Ghz which lowers the temperature to sit happily on 30C... So yeah its just Chrome being Chrome lol
System 1        System 2
System 3        System 4
        TP-Link TL-WN881ND
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12055385
Temps fine IMO. I have the i9 9900k overclocked to 5.0ghz on all cores at 1.4v. Idle 27-33c and one hour on Prime95 75-79c. I think I may have it 82c once during the hour. TJ max (thermal limit) is around 100c so if your sitting at 30c idle dont sweat it...pic is idle at a random moment while Chrome is open.
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12063318
On 12/7/2018 at 11:23 AM, DerGoliHerr said:
the launch temps were way overblown, with the latest bios on the taichi i got 100 more mhz to 5.2, just gotta be careful not to run p95 FFT on that lol... also have a downvolted profile at 4.9 1.2v for a power draw of 130w~ on cinebench, gaming never goes above 95w.
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12063401
  • 2 weeks later...
i tried running aida64 and after 5 minutes it thermal throttled to by 10% and was in the high 90's to 100's C the whole time, this was after i tested the IHS re applied a generous amount of Arctic MX-2 thermal paste and made sure the cooling block was tight and im only running on stock clock speeds and voltages. not really sure what to do now other than attempt to lower the clock speeds and make it perform worse but expand its life span.
System 1        System 2
System 3        System 4
        TP-Link TL-WN881ND
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12099530
  • 2 weeks later...
I was going to get either the I9-9900k or the I7-9700k, What cooler do you have and what Thermal compound did you use?! would love to see these temps at this OC
PC Set up
CPU: I9-9900k
Mobo: Gigabyte Z390 Aorus Pro-Wifi
GPU: MSI RTX 2070 Gamin Z
Cooling: Cooler Master ML360R AIO
RAM: Corsair Vengeance Pro RGB 16 GB 3000MHZ (8GB X 2)
RAM: Corsair Vengence Pro Lighting Enhancement Kit (0GB X 2)
Storage: Samsung 860 EVO 1TB
PSU: EVGA SuperNova G2 750 W 80+ Gold Fully Modular
Case: CoolerMaster MB511 RGB
Build Log found here:
https://linustechtips.com/topic/1004325-i9-9900k-temps/#findComment-12143080
Guest
