Whenever I try to launch Ryzen Master, the program appears to be launching, I get a transparent box and then nothing happens, it's not on my tool bar, nothing :C.
I've tried uninstalling and reinstalling several times, as well as installing on a different hard drive.
https://linustechtips.com/topic/1004186-ryzen-master-not-launching/
Seems to be an issue with the latest Ryzen Master, I had to reinstall it just to get it to open again.
Or it's an issue with the latest version of windows.
I've tried reinstalling to no avail, is there a way I can download a different version?
I think I had a similar problem with Ryzen Master in the past. Even deleting Reg Keys wouldn't let me do a proper install.
I just used the bios's overclocking functionality instead and eventually did a clean wipe of the PC.
Fan Comparisons          F@H          PCPartPicker         Analysis of Market Trends (Coming soon? Never? Who knows!)
Designing a mITX case. Working on aluminum prototypes.
Open for intern / part-time. Good at maths, CAD and airflow stuff. Dabbled with Python.
Please fill out this form! It helps a ton! https://linustechtips.com/main/topic/841400-the-poll-to-end-all-polls-poll/
I am trying the installer StreetGuru linked, I was hoping to be able to use Ryzen Master.
Overclocking your memory is likely better in the BIOS since you have to restart if doing it from Ryzen Master
I prefer the CPU overclocking in Ryzen Master since my PC will always boot to stock settings in that case.
Well I wish I could launch it, I don't think I can overclock my memory much, I am running a 3k Mhz Corsair Vengeance
