No, it probably means the cable supports a maximum wattage of 1200w. Also what cable are you referring to? If it's the one that plugs into the wall, then the cable is capable of drawing a maximum of 1200w, but your PSU will regulate the amount it needs.
print "Hello World!" ("Hello World!")
I got the power supply from my uncle about a year ago and he had a bunch of power cables to power supplies laying around and I accidentally grabbed the cable to his 1200w power supply.
Also I only found the wattage because of researching. It doesnt have it on the cable.
