1 minute ago, Dilwyn said:
Hello everybody I need help on a new case i want a good size atx case that can handle water cooling it will need to be able to mount 420mm radiator I dont mind the style as long as it isnt cheap looking thank you in advance.
What's the PC build/budget/parts/monitor resolution/refresh rate?
Or do you already own the PC parts?
https://linustechtips.com/topic/1004128-case-advice/#findComment-12042816
I already have the parts in its entirety as its my current build and my budget is about £200-250 ish.
And the water cooling parts?
You can probably make anything fit inside the Core X9, don't know if any case specifically supports 140mm radiators, maybe a fractal something
https://www.thermaltake.com/Chassis/Cube_Case_/Core/C_00002562/Core_X9/design.htm
Or this thing might have enough room, most people just use 120mm radiators...
https://linustechtips.com/topic/1004128-case-advice/#findComment-12042824
Nzxt h series cases are really nice this is mine in the h500 case.
CPU:R9 3900x@4.5Ghz RAM:Vengeance Pro LPX @ 3200mhz MOBO:MSI Tomohawk B350 GPU:PNY GTX 1080 XLR8
DRIVES:500GB Samsung 970 Pro + Patriot Blast 480GB x2 + 12tb RAID10 NAS
MONITORS:Pixio PX329 32inch 1440p 165hz, LG 34UM68-p 1080p 75hz
https://linustechtips.com/topic/1004128-case-advice/#findComment-12042838
Yeah i got all the water cooling parts to I literally wanna take my system and transfer it to a new case as my case is beyond knackered.
https://linustechtips.com/topic/1004128-case-advice/#findComment-12042860
Thats a nice case certainly one to look into although on look at the spec sheet i wouldn't be able to fix my current radiator in.
Edited by Dilwyn
https://linustechtips.com/topic/1004128-case-advice/#findComment-12042863
Look at the h700 cases
https://linustechtips.com/topic/1004128-case-advice/#findComment-12042882
Cant fit a 420mm rad. Max listed support for the H700 is 360mm rads
There's a limited list of modern cases that can support 420mm rads.
Fractal Desing Define R6 / S / S2 (Top only)
Phanteks Evolv X (Front only)
be quiet! Dark Base Pro 900 / 900 rev 2
Thermaltake Core X71 / V71 / A500
Sadly the Lian Li case Does not support a 420mm rad
This is just what I know/could find relatively quickly. Note that your thickness of your rad will determine compatibility, as I dont believe you can fit a particularly Thick rad in the Fractal Design cases for example (Ram Clearance)
https://linustechtips.com/topic/1004128-case-advice/#findComment-12044990
