I need help making sure all these parts work together (ordering tomorrow please help)
Hi so im upgrading some components. Im kinda brokeish and im shipping it over seas so i need to make sure it all fits.
Existing parts:
Gtx 970 strix
Cooler master 212 fan
New parts:
Ryzn 5 2600 (idk if i should just get like the 1600 since i already have a graphics card and this is already kinda stretching my budget of 100- 150$)
Gigabyte GA-AB350 (any better suggestions would be amazing)
Corsair Vengeance LPX 2x4 kit
Are you trying to reuse ram? Ryzen used ddr4 and thr ram for your 2500k is going to be ddr3 and incompatible.
Your parts list looks good so far. How about you edit your original post to include a list from pcpartpicker.com, it makes it super easy to see.
Primary PC:
Is this bios issue a big deal? Should i try another motherboard?
The majority of B350 boards don't have the issue anymore. If it does happen and you can't boot, AMD has a free boot kit you can use. They send you their cheapest cpu, you update your BIOS, and you send it back (without the heat sink for some reason)
Primary PC:
but other than that does it look all good? also thank you sooooo much
