Need help in CSS
Go to solution Solved by FlappyBoobs,
2 hours ago, Ashish Sharma-RSi said:
Tried the inspector, still can't fig. out the problem. I know, it is in the padding or margin, but can't seem to figure it out.
I missed the css the first time, sorry about that! I've had a look but don't have more than notepad and chrome at the moment (on mobile). I think that you should look at your column layout. At the moment they are behaving like 4 individual elements, rather than 2 rows of 2 elements, which is what I think you are after. As they all have different amounts of text that throws off the layout as they are all different sized boxes (height) as you use % widths on all the boxes at once.
Try wrapping the two boxes you want in a row, and the setting the widths and heights to match each other so that the boxes are all the same size, use margin and padding on the boxes to get everything looking good.
I hope that helps point you in the right direction.
can you link me to your code? its hard to know whats wrong without knowing whats going on
✧・゚: *✧・゚:*  Quote for a reply  *:・゚✧*:・゚✧
✧・゚: *✧・゚:*   Ask for discord   *:・゚✧*:・゚✧
https://linustechtips.com/topic/1003398-need-help-in-css/#findComment-12036020
4 minutes ago, Ashish Sharma-RSi said:
They are just floating div's.
That's what I thought but without the code, I don't know what you did wrong. Have you tried implementing Bootstrap into it ? it's really easy once you get the hang of it.
https://linustechtips.com/topic/1003398-need-help-in-css/#findComment-12036033
Here we go...
https://drive.google.com/open?id=1C-a5m6wMsJh723gGeaijA16Rwm0RSXwB
https://linustechtips.com/topic/1003398-need-help-in-css/#findComment-12041269
25 minutes ago, Ashish Sharma-RSi said:
can i have a .txt file? im on ios and cant open .html files
https://linustechtips.com/topic/1003398-need-help-in-css/#findComment-12041370
16 hours ago, Ashish Sharma-RSi said:
You've not included the CSS you've used, which is where the problem lies.
Most likely you've not set the display attribute correctly or your wrapped column is too wide for both to fit. What does the inspector tell you when you open it?
Take a look into W3C for flex grid as that will help you a lot. Or just take a look below if you are happy to look at code (this is not my example so I provide no warranty :) )
https://codepen.io/MattWindle/pen/perZRG
https://linustechtips.com/topic/1003398-need-help-in-css/#findComment-12044345
CSS is there in the folder "css"
Added .txt files for both css and html.
Thanks, a lot for helping.
https://linustechtips.com/topic/1003398-need-help-in-css/#findComment-12045489
https://linustechtips.com/topic/1003398-need-help-in-css/#findComment-12045505
https://linustechtips.com/topic/1003398-need-help-in-css/#findComment-12046146
Thanks a lot for that.
https://linustechtips.com/topic/1003398-need-help-in-css/#findComment-12049641
