Hello lovely LTT-Community ❤️
I wanted to ask if there is any good thermal paste? Currently i use the Noctua NT-H1 for my Ryzen 7 1700X at 4GHz. When i do a stresstest with Aida64 for 1 hour it get's never over 60° Celsius.
I hope you guys can recommend me a good thermal paste that is a bit better then the NT-H1.
CPU: Ryzen 7 1700X @4GHz   GPU: Asus Rog Strix GTX 1080 A8G
Motherboard: Asus Rog Strix X370-F Gaming   RAM: G.Skill TridenZ 2x8GB 3200MHz CL14
Case: Corsair Obsidian Series 750D   Storages: Samsung 970 Evo 250GB, 250 SanDisk SSD, 2TB Toshiba HDD
CPU Cooler: Corsair H110i 280mm AiO   PSU: Corsair RM750X 750W   Operating System: Windows 10 Pro 64Bit
Keyboard: Roccat Vulcan 120   Mouse: Roccat Kova   Headset: HyperX Cloud 2
https://linustechtips.com/topic/1002171-best-thermal-paste/
best ?
Arguably...
Thermal Grizzly Kryonaut (non metalic)
or
Conductonaut (liquid metal)
NT-H1 is no slouch tbh, its a good TIM.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1002171-best-thermal-paste/#findComment-12025767
even better paste can only bring temps by another 1 or 2 C down, so don't expect much
Desktop benching:
https://linustechtips.com/topic/1002171-best-thermal-paste/#findComment-12025778
Thermal paste is near meaningless, just get a decent one and call a day.
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1002171-best-thermal-paste/#findComment-12025805
I would have expected round about 5° Celsius difference but really only 1 to 2? Thats kinda low :/
https://linustechtips.com/topic/1002171-best-thermal-paste/#findComment-12025849
It depends on various factors, but generally between the better ones the differences in practice aren't great. Maybe if you had a really bad one to start with you would see a bigger change.
The only situation where it make much of a difference is if you are delidding an Intel CPU, or going extreme overclocking.
https://linustechtips.com/topic/1002171-best-thermal-paste/#findComment-12025890
because NT-H1 is a decent paste in the first place.
Desktop benching:
https://linustechtips.com/topic/1002171-best-thermal-paste/#findComment-12025933
I mean.... is it even possible to buy crappy paste now-a-day? You'd have to go out of your way considering even good paste is super freaking cheap. What exactly would be considered crappy paste? I got some "questionable" paste with my hyper 212, but other wise the only pastes I've collected have been Arctic silver 6 and the noctua pastes.
I mean honestly all of these results (for the normal pastes) are within margin of error in my opinion. (Unless they're using a screenprinter or tape casting to apply the paste to the CPU, there's going to be variability, certainly more than 0.1 C. I doubt the temperature sensors inside the chip are even accurate to 0.1C.)
aHR0cDovL21lZGlhLmJlc3RvZm1pY3JvLmNvbS9Y
https://linustechtips.com/topic/1002171-best-thermal-paste/#findComment-12026021
So you guys suggest me to stick with my Noctua NT-H1?. If so it can't be helped :/ I really was hoping to lower it by about 5 degrees.
https://linustechtips.com/topic/1002171-best-thermal-paste/#findComment-12026205
