Upgraded old system using same RTX 2080
Upgraded old system from a:
4790K 4.60Ghz 1.290v
Corsair H100iv2
Asus Maximus VII Hero 3201 Z97
Dominator Platinum DDR 3 2.40GHz 16GB 1.65v
Nvidia RTX 2080 1.95GHz 7.00Ghz
Cosair AX860 PSU
Cosair 460x case with 6 fans
850EVO 500GB
Upgraded system:
9700K 5.00GHz stock volts
Cosair H100iv2
Aorous Z390 Ultra R5 bios
Gskill Trident Z RGB 3.20GHz 16-18-18-38-1T 16GB 1.35v
Nvidia RTX 2080 1.97GHz 7.00Ghz
Cosair AX860 PSU
850EVO 500GB
My results are awesome system upgrade made a huge difference in gaming I can now play 4K Ultra Blacks Ops 4 Black out steady 60FPS+ no dips as with my old system I was getting 45-60 dips now is steady 60+ FPS. I don’t know if my old system was already dieng or not enough CPU power for the RTX 2080  costly upgrade but I like it.
https://linustechtips.com/topic/1002167-upgraded-old-system-using-same-rtx-2080/
Cpu shouldn't really matter for 4k unless Blops4 is shitty on the cpu, like the Asscreed games.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
Frametime / 1% and 0.1% lows are a thing too did you know? It ain't just about fps averages.
Personal Desktop":
Luna, the temporary Desktop:
it definitely matters, even farcry 5 on 4k medium requires cpu, once you get over 80ish fps some cpus just choke, not even talking about the cpus that chokes in the 40s (4790k/8600k cough cough)
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
This is why I'm scared to make the dip into 4K, as I still hold onto my 4790K. even thought I'd be better served with more cores..
Once I go down that rabbit hole so does my wallet/savings account ?
When the PC is acting up haunted,
who ya gonna call?
"Monotone voice" : A local computer store.
*Terrible joke I know*
Yeah I was in the same boat as you but I got a good deal out the door cpu mobo and DDR4. I’m done for 4-5 years
ya, i was talking to a friend, he bought a pre-built 8700/1060 for a decent price. He has a 1080p/60 monitor
"as long as you don't upgrade your monitor you are fine"
I went over each upgrade option with him and the numbers got outta hand pretty quickly. "120hz+1070 ti=500usd, oh you might need a new psu, 600"
Me? I have Corsair AX860
Your CPU is holding you back when you see its usage is at 100 percent in a game.  Then it is pretty much choking..
Me personally, I play 2 games,, Quake Champions and Unreal Tournament Alpha.  I play @ 1080p all nv panel settings turn On, and all options set to max, AA etc etc..  All in game settings for Quake Champions set to ultra and resolution scaling set to 110 percent and I get 60fps at all times and never dips.  It does go to 40's only after a frag and if theres water everywhere and characters etc.. I mean I don't see that usually when gaming 8 players in the match.  UT same thing its stuck at 60fps all settings to ultra high and 1080p of course,,,, All a RTX card can really do for me to change my gaming experience is game @ 4k ……  and honestly after all those AA methods I don't see jaggies,, Im find with 1080p.  If I had a 1080 I bet I could do 1440p 60fps locked.  sighs
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
