3 minutes ago, Andrew.Schickowski said:
a really nice unit for this pc would be an evga super nova g3 750 watt
750W???? 550W is enough.
Anyway, for a good 550W unit, i'd recommend the RM550x although I don't know if EVGA has a G2 or G3 that's 550 or 500w only.
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1002074-building-a-pc/#findComment-12024806
I have an EVGA G2 550w PSU. Seems to do the trick and is near silent.
https://linustechtips.com/topic/1002074-building-a-pc/#findComment-12024883
1 minute ago, AshenFire said:
i still have one problem i want to buy an gtx 1080 ti and i need to know if 550 watt are enought
It's better to get 650W, although 550W would probably be enough 650W or 750W would give room for upgrades
https://linustechtips.com/topic/1002074-building-a-pc/#findComment-12024894
Isn't the g3 really fucking loud?
edit: seon123 already established the issue with this psu
8086k
aorus pro z390
noctua nh-d15s chromax w black cover
evga 3070 ultra
samsung 128gb, adata swordfish 1tb, wd blue 1tb
seasonic 620w dogballs psu
https://linustechtips.com/topic/1002074-building-a-pc/#findComment-12026793
Yeah any ATX size psu will fit.
Be sure to check our forums PSU tier list however and select a PSU from tier 1 or 2 to get a decent one that won't kill your pc and light your house on fire.
Edit: the vengeance seems to be in tier 2, so you are good to go.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1002074-building-a-pc/#findComment-12029221
ASUS X470-PRO • R7 1700 4GHz • Corsair H110i GT P/P • 2x MSI RX 480 8G • Corsair DP 2x8 @3466 • EVGA 750 G2 • Corsair 730T • Crucial MX500 250GB • WD 4TB
https://linustechtips.com/topic/1002074-building-a-pc/#findComment-12029455
