LED strips count as peripherals, right?
Go to solution Solved by r4tch3t,
4 minutes ago, bigmouthbob1 said:
So I got this $5 led strip on sale at Walmart and I was wondering if I cut it on the thin black line (in the pic) would it ruin them?
Unlikely, it depends on the strip but that one looks like the proper place to cut. They are wired in parallel usually.
Those can probably be cut there, yeah.
@bigmouthbob1 I'll confirm what @r4tch3t said. I work in Product Development at my job. Those lines are the circuitry. Every black line represents where LED strips can be cut without breaking a proper circuit. The only caution is to cut directly in the middle as accurate as possible.
