Help Corsair h100i V2 aio liquid cooler.
Solved by aezakmi,
1 hour ago, Frank Cisco said:It stops because if the temp of the CPU is below some number , I really don't know what determines it , I just runned the qfan utility that the bios has,it stops , and when I'm gaming, it turns on . Also if the CPU gets hotter no matter if I set them static RPM, they rev up to the max to cold everything,MoBo , CPU, GPU.
so you're still in auto mode, switch to manual to override any mess caused by these utilities, manufacturers just add that kind of stuff to have something to brag about and also increase board price
