How do I shorten and sleeve fan cables
Solved by Necrodead,
To shorten them you'll need new crimper pins, a special tool for crimping them, and then all the sleeve you'll need. 3-4mm for fan cables, and heat shrink. Oh and the tool for removing the pins, although something narrow and metal also works.
https://www.dazmode.com/store/product/female_kk_crimp_pin_for_3-pin_fan_connector_pack_of_3_/
https://www.dazmode.com/store/product/6-in-1-multi-purpose-wire-pliers-and-m2-m5-screw-cutter/
https://www.dazmode.com/store/category/fan-and-pump-wires-sleeve/
https://www.dazmode.com/store/product/fan-connector-removal-tool-3-and-4-pin/
Honestly shortening them is so much work I don't even do it, and I sleeve all my own PSU wires. I would just sleeve them and find a place to tuck them away.
