Stock CPU Fan failing in Oil Cooled Machine
Solved by Angry Postman,
It's in! Getting oil temps up to 34 playing YouTube. Sits at 29 running Kodi. Water temperature seams completely unaffected! Weird...
Fish seem very happy (probably due to the partial water change). They're all swimming about happily.
Only problem is my USB header cable for the front panel came loose! I'm really tired of being full of oil and sliding all over the place. But it just needs to be plugged back in... At the bottom of the motherboard... Halfway down the oil tank... Sigh...
I'm going to post a video soon.
