Best high pressure led fans?
kristaps552
So, i've decided to upgrade my cpu from an I3 2100 to a 3570k, and i dont think that my asus royal knight 2 can handle overclocks, so i've decided to upgrade to a 212 evo, but here is the thing, I want the fans on the 212 evo to be led fans, preferably green, but wouldnt mind red, but not blue, so which would be the best led fans with good static pressure that I could mount on 212 evo in p/p? I dont mind loud fans, as long as not overly loud.
Case:NZXT H440   CPU:3570k @ 4.4ghz   Cooler:Prolimatech Megahalems w/ ap121 p/p  GPU:Gigabyte Windforce GTX 770  RAM:Crucial Ballistix Tactical Tracer 16gb 1600mhz  Mobo:Sabertooth Z77     PSU:Cooler Master Silent Pro M 700w   Wheel: Logitech G27 + joystick as handbrake Asus DGX 5.1        Mouse: Corsair M65     Keyboard: CM Storm Trigger Cherry MX black  Headphones: ATH-M50s    Phone: Nexus 5 32GB  Earphones: Sennheiser CX 400ii    SSD: 120gb 840 evo  HDD: WD Enterprise 2TB    AMP&DAC: Schiit Stack.
Silverstone Air Penetrators have LED's.
Thanks, appreciate your help. :)
The Silverstone Air Penetrators have quite a few colours, there's normal blue, UV blue, blue LED, red LED and green LED
  • 2 weeks later...
Enermax makes some nice quiet, high pressure LED fans. I'm using two of them and haven't had any issues.
best pressure would be the air penetrators, but the bitfenix spectre pro is close
by .5mm, but have a wider LED color palette..
airdeano
