Help choosing a fit monitor
Elwing
Hello everyone!
I am struggling for a few days to pick a fit monitor for my needs and budget. I am working as a programmer, and I am ocasionally gaming. My budget goes at around 250$ at most and I am trying to find the best value on the market. Here's what I found so far:
-https://www.newegg.com/asus-va24dqlb-23-8-full-hd/p/N82E16824281076
-https://www.amazon.co.uk/Philips-245E1S-00-Monitor/dp/B07SPCWZHP
-https://www.newegg.com/lenovo-24/p/0JC-0006-00UR2?Description=L24q-30
-https://www.amazon.co.uk/AOC-I2790VQ-BT-Widescreen-Multimedia/dp/B06ZY72NK1
-https://www.newegg.com/benq-gw2480-24-full-hd/p/N82E16824014466?Description=GW2480
-https://www.newegg.com/p/N82E16824025515?Description=24MP59G-P&cm_re=24MP59G-P-_-24-025-515-_-Product
My search criteria contains:
-IPS panel
-5ms response rate
-24-inch display pref
-75Hz refresh rate
If anyone can give a hand or a recommendation to pick any of those or if they know something better, I'd sincerely appreciate the help.
Thank you for your time reading this!
I’m just gonna suggest my monitor that is usually 250 on amazon
1080p at 27” 165hz for your budget
https://www.amazon.com/gp/product/B07XV1519W/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
out of stock right now, but they come back every once in a while
PCPartPicker Part List: https://pcpartpicker.com/list/qJB4Xv
CPU: Intel Core i7-9700K 3.6 GHz 8-Core Processor  ($269.00 @ Amazon)
CPU Cooler: MSI MAG CORE LIQUID 240R 78.73 CFM Liquid CPU Cooler  ($109.99 @ Amazon)
Motherboard: Asus ROG STRIX Z390-E GAMING ATX LGA1151 Motherboard  ($394.98 @ Amazon)
Memory: G.Skill Trident Z RGB 32 GB (4 x 8 GB) DDR4-3000 CL15 Memory  ($174.99 @ Amazon)
Storage: Samsung 860 Evo 1 TB 2.5" Solid State Drive  ($99.99 @ Amazon)
Storage: Seagate Barracuda Compute 2 TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Newegg)
Video Card: MSI GeForce RTX 2080 SUPER 8 GB GAMING X TRIO Video Card  ($869.99 @ Staples)
Case: Thermaltake V200 RGB ATX Mid Tower Case  ($79.98 @ Amazon)
Power Supply: Asus 850 W 80+ Platinum Certified Fully Modular ATX Power Supply  ($229.64)
Total: $2338.54
Generated by PCPartPicker 2020-12-08 10:04 EST-0500
AOC 24G2U
Fit most of your criteria
IPS
24"
$180
1ms response time
144Hz(can run slower, etc 60Hz, 80Hz, 100Hz)
