When playing games for 20 minutes and more its starting to get power limit throttled. Sometimes current limit throttled. This happened from past month. I am using a  under volt of -0.125 v from the beginning of this usage by testing benchmarks and so. And this charging cable was patched (i don't know whether the problem is this or not). Reinstalled the OS, re pasted, under volt don't know what to else. sometimes current limit throttling appears. very rarely thermal throttles. What must be the problem.
Power and current limits are not a problem, but rather opportunistic, allowing the CPU to reach its maximum potential for the platform.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Fedora 38 x86_64
Secondary: AMD Ryzen 5 5600G, 16 GB 2667 MHz DDR4, Fedora 38 x86_64
Server: AMD Athlon PRO 3125GE, 32 GB 2667 MHz DDR4 ECC, TrueNAS Core 13.0-U5.1
Home Laptop: Intel Core i5-L16G7, 8 GB 4267 MHz LPDDR4x, Windows 11 Home 22H2 x86_64
Work Laptop: Intel Core i7-10510U, NVIDIA Quadro P520, 8 GB 2667 MHz DDR4, Windows 10 Pro 22H2 x86_64
Asus rog GL503GE btw
I5-8300h
8gb ddr4 2666mhz
Gtx 1050ti 4gb
I get power and current limit throttling is good. But this happens suddenly out of no where. Previously I was able to run most of the game whithout any problem. Why now.
Previously every games works fine. Very few times thermal throttling. But not power and current limit throttling. Why suddenly it came
19 hours ago, pilot35 said:
Laptop model and specs?
Asus gl503ge
I5 -8300h
8gb ddr4 2666mhz
Gtx 1050ti 4gb
I get it. I know throttling is not to bypass the threshold. But my main point is why suddenly I'm getting throtling. Previously I didn't got any throttling when using the same tasks but why now.
While throttling fps drops to 20 and gets back after ~20 seconds.
