Yamaha MG10XU Problem
furbz
Hey guys i bought a Yamaha MG10XU so i could stream well i'm having a problem with the with something i don't know if its the board or me just not having it set up right but every time i watch a YouTube video where there is music playing while someones talking, the music is louder then the persons voice and i don't know how to fix it except using the karaoke effect for that line.
I Have tried:
  • using a different USB port (went from 2.0-3.0)
  • using a different cable
  • updated all audio drivers
has anyone else had this problem and was able to fix it?
If you're streaming an Audio interface should be what you use to get your voice into the PC, not a mixer but in reality the answer is that there's no reason for that level mismatch to be happening. VO and music in YouTube are baked into the same stereo track so there's no way to increase the volume of one of the other (without targeted EQ or a specialised program like RX7 or Spleeter).
Try removing any effects you have on and listening to the video both directly and then monitoring through OBS to see where the level mismatch is happening, if you can hear it fine you have something funky going on, if you hear it screwy as well it may just be a badly mixed video.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
im still having it in both its like the sound that coming from YouTube is getting messed up in the mixer because if i unplug my headset and directly plug it in to the pc there is no problem the voice and music i can hear equally just not when im plugged in the the mixer
