Gsync module vs Gsync compatible for ~60fps questions
Solved by Samfisher,
A proper G-Sync panel will guarantee flawless LFC and VRR from 30hz -> maximum refresh rate of the panel. Freesync does seem to have a lot of problems when playing at the border between VRR and non VRR FPS ranges. Freesync also doesn't dictate the ranges of LFC and VRR, so that's up to the monitor manufacturers to decide on.
I've had the XB271HU, which is essentially the same as the PG279Q (same panel). I just sold that panel to a friend and I'm waiting on my Odyssey G7 which is Freesync/G-Sync compatible instead of G-Sync, and I'm hoping I don't regret this decision cos the G7 has a VRR range of 60-240hz.....
All in all the PG279Q is a really nice monitor.
