RGB control between Asrock b450m pro4 and nzxt h510i
bdk74
Hi,
I didn't plan on going RGB for my build but I have the option to buy the 510i for less than 510.
SInce I'm new to the concept of RGB can someone let me know if the mobo will support the 510i SMART DEVICE V2 (H510i)?
From the mobo manual it says it has RGB LED Header (RGB_HEADER1). But I'm not sure if this is it or not.
Thank you in advance for your assistance.
