Cable management (Power, Data, HDMI, DP, etc.)
Keiran1983
Hi all,
I need some help to manage the cables behind my 4x monitors and PC casing.  As u can see from the pictures below, it is messy AF.  Any help or advice will be great!  Thanks in advance!
For cables on and under the table you can use the cable tray build into the table.
As for the cable attached to the monitors:
You can buy some velcro straps and attacht the cables to the display arms.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
also i would suggest a ups
MSI x399 sli plus  | AMD theardripper 2990wx all core 3ghz lock |Thermaltake flo ring 360 | EVGA 2080, Zotac 2080 |Gskill Ripjaws 128GB 3000 MHz | Corsair RM1200i |150tb | Asus tuff gaming mid tower| 10gb NIC
  • 1 year later...
On 1/29/2020 at 2:47 PM, Keiran1983 said:
Hi all,
If this is still an issue you could try something like this.
Also, I did buy a lot of (good) cables (USB, Sound, HDMI...) to the right size from AliE. That helps.
I'm willing to swim against the current.
