Need help regarding RGB of Corsair Vengeance PRO
8 minutes ago, The Illuminazi said:I have a ROG B450F mobo and occupied the ram slots with corsair vengeance pro rgb 3200mhz 8gb sticks in the order Cooler>empty>Dimm1>empty>Dimm2
I bought one when buying the pc (couldnt buy the second one cuz they were out of stock, got the 2nd stick a few days later) When I added the new stick it lit up when turning on but after pc was running couldnt get one stick rgb to turn on (system detected both ram tho)
After shuffling around few restarts later got both rgb to work (sync with aura and iCUE) but in one ram the rgb is reverse for some reason. say the lighting is supposed to shift from top to bottom, one ram does as the software shows but the other ram does the opposite (bottom to top) iCUE visualizations show it should both be going top to bottom, same with Aura. One ram rgb moves in the wrong direction. How do I fix this? Really frustrated used all my part time earnings for this pc >.<
Did you change dim layout in icue? also make sure the firmware is up to date. I want to say at one point i had that issue. But its been a while back.
