Do I need a sound card for ASUS ROG Delta USB C headset?
Rolling2405
5 hours ago, Thomas001 said:
I am think of getting this headphone. Should I get a sound card?
You could they aren't very power hungry. If your motherboard is good enough then great. My general advice is buy the headphone run off your motherboard if it's not loud enough or you hear alot of electrical noise  then buy a dac/amp my suggestion would be the fiio k5 pro. And in terms of mic if your not streaming a blue snowball should serve almost anyone perfectly
@rice guru Is the Akg k371 good for gaming too or do I need to get another headphone for gaming?
  • My system specs
  • View 91 Tempered Glass RGB Edition, No PSU, XL-ATX, Black, Full Tower Case
  • ROG MAXIMUS XI EXTREME, Intel Z390 Chipset, LGA 1151, HDMI, E-ATX Motherboard
  • Core™ i9-9900K 8-Core 3.6 - 5.0GHz Turbo, LGA 1151, 95W TDP, Processor
  • GeForce RTX™ 2080 Ti OC ROG-STRIX-RTX2080TI-O11G-GAMING, 1350 - 1665MHz, 11GB GDDR6, Graphics Card
  • ROG RYUJIN 360, 360mm Radiator, Liquid Cooling System
  • 32GB Kit (2 x 16GB) Trident Z DDR4 3200MHz, CL14, Silver-Red DIMM Memory
  • AX1600i Digital, 80 PLUS Titanium 1600W, Fanless Mode, Fully Modular, ATX Power Supply
  • Formula 7, 4g, 8.3 (W/m-K), Nano Diamond, Thermal Compound
  • On AIO cooler 6 x NF-F12 IPPC 3000 PWM 120x120x25mm 4Pin Fibre-glass SSO2 Heptaperf Retail
  • 6 x NF-A14 IPPC-3000 PWM 140mm, 3000 RPM, 158.5 CFM, 41.3 dBA, Cooling Fan
  • 1TB 970 PRO 2280, 3500 / 2700 MB/s, V-NAND 2-bit MLC, PCIe 3.0 x4 NVMe, M.2 SSD
  • Windows 10 Pro 64-bit
  • Beyerdynamic MMX 300 (2nd Generation) Premium Gaming Headset
  • ROG PG279Q
  • Corsair K95 Platinum XT
  • ROG Sica
One advantage some of these USB "gaming" headsets have is the ability to hear yourself on the mic in the headphones.  Because of this I bought the USB dongle for the Logitech G430, but not the headphones.  The USB dongle has analog jacks that you can plug your headphones into and your mic.  My on-board audio wasn't nearly as low latency as the USB dongle is.
Edit:
https://smile.amazon.com/OEM-Part-GenuineLogitech-Surround-Headset/dp/B00PZC792K/ref=sr_1_6?keywords=logitech+g430+dongle&qid=1573524057&sr=8-6
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
it has a deently wide sound stage with decent imagin overall will work just as good as any gaming headset for gaming.
another headphone to consider is the mmx 300 comes with a pretty
damn decent mic
damn decent mic
What do you think of these headphones for pop, easy listening, and 80s and 90s music? These look pretty good as well so I am trying to decide between the mmx 300 and Akg 371
  • My system specs
  • ROG PG279Q
  • ROG Sica
Both will do a great jobat that. I personally love how Beyers sound and for gaming they are my fist pick in my personal collection  so out of the 2 I would prob end up getting the mmx 300. But the akg is great too just not as good for gaming.
I will probably go with the mmx 300 then. The 2nd gen is the one I am planning on getting.
  • My system specs
  • ROG PG279Q
  • ROG Sica
thats great!. hope you enjoy them
