(ErP/EuP ready power supply is required)
It's not really required... a power supply that can do those is only needed if you want enable and use power savings modes that put your computer to deep sleep / standby , stuff like that.
A power supply that doesn't have those features may not be able to provide a stable 12v and 5v at very low power consumption, like 5-10w, which can happen if the motherboard commands the video card and processor to go in "sleep mode" if you don't touch anything or use the computer in some way for a while. If psu can't handle it, then pc could shut down or reset instead of waking up normally from sleep mode. If you don't use these features, you'll be perfectly fine.
Your computer would work just fine with that Corsair VS550
in general, gold efficiency power supplies from reputable brands will have no problems even if they don't advertise that they're ErP/EuP "compatible"
