Posted May 23, 2019 Hello all! I'm tied between the Corsair Crystal 570X White RGB or the Lian LI PC-001 Dynamic White. I understand they are different configurations, but which would be better? I like the way they both look, though here is the issue: Corsair: Doesn't support a 360mm radiator at the top. Would putting it on the front intake cause the case to run hot? I see a lot of people putting a 360 radiator in the front, I was worried about thermals. LI PC-001: Doesn't look as good and doesn't have the upgradability as the 570x. Can I get your thoughts? Some pros and cons of both cases? Edit: I will do future liquid cooling, but for the time sake, I will keep my aio. Thanks, Loch ( ͡~ ͜ʖ ͡°) ( ͡~ ͜ʖ ͡°) ( ͡~ ͜ʖ ͡°) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 lol i had the same dilemma but also with the crystal 680x. overall, the o11 dynamic is a better designed case, which is why i just earlier tonight bought one Bethesda PC: R7 3700X - Asrock B550 Extreme 4 - Corsair Dominator Platinum RGB 16GB@3.6GHz - Zotac AMP Extreme 1080TI - Samsung 860 Evo 256GB - WD Blue 2TB SSD - 500DX - Stock cooling lul - Rm650x CrumpleBox V3: Xeon X5680 - Asus X58 Sabertooth - DDr3 16GB@1.33Ghz - Gigabyte 1660s - TT smart RGB 700W - Cooler Master Storm Trooper - 120GB Samsung 850 Pro - LTT Edition Chromax NH-D15 CrumpleBox 3 ROTF: I5-6400 - MSI B150m Mortar - 16GB 2133Mhz Vengeance Pro RGB - Strix 1070Ti - GTX 1070 FE - Adata 128GB SSD - Fractal Design Define C - Gammaxx 400V2 - Cooler Master silent pro gold 1000W CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X Perhiperals: Gateway 900p60 monitor - Dell 1024x768@75 - Logi. G403 Carbon - Logi. G502 - SteSer. Arctis 5 - SteSer. Rival 110 - Corsair Strafe RGB MK.2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 LIAN LI PC-001 Dynamic White. It has a very good air flow!! CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 10 minutes ago, Constantin said: LIAN LI PC-001 Dynamic White. It has a very good air flow!! once you but fans for it lol Bethesda PC: R7 3700X - Asrock B550 Extreme 4 - Corsair Dominator Platinum RGB 16GB@3.6GHz - Zotac AMP Extreme 1080TI - Samsung 860 Evo 256GB - WD Blue 2TB SSD - 500DX - Stock cooling lul - Rm650x CrumpleBox V3: Xeon X5680 - Asus X58 Sabertooth - DDr3 16GB@1.33Ghz - Gigabyte 1660s - TT smart RGB 700W - Cooler Master Storm Trooper - 120GB Samsung 850 Pro - LTT Edition Chromax NH-D15 CrumpleBox 3 ROTF: I5-6400 - MSI B150m Mortar - 16GB 2133Mhz Vengeance Pro RGB - Strix 1070Ti - GTX 1070 FE - Adata 128GB SSD - Fractal Design Define C - Gammaxx 400V2 - Cooler Master silent pro gold 1000W CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X Perhiperals: Gateway 900p60 monitor - Dell 1024x768@75 - Logi. G403 Carbon - Logi. G502 - SteSer. Arctis 5 - SteSer. Rival 110 - Corsair Strafe RGB MK.2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 1 hour ago, GrockleTD said: once you but fans for it lol your sentence doesn't make sense.... CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 Just now, Constantin said: your sentence doesn't make sense.... lol i haven't had much sleep today, that was mean't to say buy not but Bethesda PC: R7 3700X - Asrock B550 Extreme 4 - Corsair Dominator Platinum RGB 16GB@3.6GHz - Zotac AMP Extreme 1080TI - Samsung 860 Evo 256GB - WD Blue 2TB SSD - 500DX - Stock cooling lul - Rm650x CrumpleBox V3: Xeon X5680 - Asus X58 Sabertooth - DDr3 16GB@1.33Ghz - Gigabyte 1660s - TT smart RGB 700W - Cooler Master Storm Trooper - 120GB Samsung 850 Pro - LTT Edition Chromax NH-D15 CrumpleBox 3 ROTF: I5-6400 - MSI B150m Mortar - 16GB 2133Mhz Vengeance Pro RGB - Strix 1070Ti - GTX 1070 FE - Adata 128GB SSD - Fractal Design Define C - Gammaxx 400V2 - Cooler Master silent pro gold 1000W CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X Perhiperals: Gateway 900p60 monitor - Dell 1024x768@75 - Logi. G403 Carbon - Logi. G502 - SteSer. Arctis 5 - SteSer. Rival 110 - Corsair Strafe RGB MK.2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 1 hour ago, GrockleTD said: lol i haven't had much sleep today, that was mean't to say buy not but Of course once you buy them. You even have the plus to choose them! As one fan from another may result in close to zero airflow. Investing in case fans is very important and can have a huge difference. CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 1 minute ago, Constantin said: Of course once you buy them. You even have the plus to choose them! As one fan from another may result in close to zero airflow. Investing in case fans is very important and can have a huge difference. well, i was specifically referring to the fact that it doesn't come with any, which is something to keep in mind Bethesda PC: R7 3700X - Asrock B550 Extreme 4 - Corsair Dominator Platinum RGB 16GB@3.6GHz - Zotac AMP Extreme 1080TI - Samsung 860 Evo 256GB - WD Blue 2TB SSD - 500DX - Stock cooling lul - Rm650x CrumpleBox V3: Xeon X5680 - Asus X58 Sabertooth - DDr3 16GB@1.33Ghz - Gigabyte 1660s - TT smart RGB 700W - Cooler Master Storm Trooper - 120GB Samsung 850 Pro - LTT Edition Chromax NH-D15 CrumpleBox 3 ROTF: I5-6400 - MSI B150m Mortar - 16GB 2133Mhz Vengeance Pro RGB - Strix 1070Ti - GTX 1070 FE - Adata 128GB SSD - Fractal Design Define C - Gammaxx 400V2 - Cooler Master silent pro gold 1000W CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X Perhiperals: Gateway 900p60 monitor - Dell 1024x768@75 - Logi. G403 Carbon - Logi. G502 - SteSer. Arctis 5 - SteSer. Rival 110 - Corsair Strafe RGB MK.2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 1 hour ago, GrockleTD said: well, i was specifically referring to the fact that it doesn't come with any, which is something to keep in mind The majority do not come with fans and if they do, they are to be replaced. except on very expensive high end cases, that still some fans are not included CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 The answer is always "Fractal Design". Then again you seem to have your heart set on a white TG case and the S2 Vision apparently isn't available in white. The 360 rad in the front will increase the air temperature inside the case perhaps with 1 or 2 °C. It won't really make a difference for the GPU and definitely not for the CPU. So I wouldn't worry too much about that. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 6 hours ago, quakeguy81 said: NZXT H500 Radiator in front intake. There's no intake at the front in a nzxt h500, itll choke/beg for fresh air. It has bad airflow generally Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 @Loch fractal design meshify C? White, TG, and extremely good airflow. MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x | NZXT Kraken X52 | MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro Wireless | Gigabyte Aurus AD27QD Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 1 hour ago, Stormseeker9 said: @Loch fractal design meshify C? White, TG, and extremely good airflow. most importantly, unlike most fractal design cases, doesn't cost an arm and both legs Bethesda PC: R7 3700X - Asrock B550 Extreme 4 - Corsair Dominator Platinum RGB 16GB@3.6GHz - Zotac AMP Extreme 1080TI - Samsung 860 Evo 256GB - WD Blue 2TB SSD - 500DX - Stock cooling lul - Rm650x CrumpleBox V3: Xeon X5680 - Asus X58 Sabertooth - DDr3 16GB@1.33Ghz - Gigabyte 1660s - TT smart RGB 700W - Cooler Master Storm Trooper - 120GB Samsung 850 Pro - LTT Edition Chromax NH-D15 CrumpleBox 3 ROTF: I5-6400 - MSI B150m Mortar - 16GB 2133Mhz Vengeance Pro RGB - Strix 1070Ti - GTX 1070 FE - Adata 128GB SSD - Fractal Design Define C - Gammaxx 400V2 - Cooler Master silent pro gold 1000W CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X Perhiperals: Gateway 900p60 monitor - Dell 1024x768@75 - Logi. G403 Carbon - Logi. G502 - SteSer. Arctis 5 - SteSer. Rival 110 - Corsair Strafe RGB MK.2 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted May 23, 2019 27 minutes ago, GrockleTD said: most importantly, unlike most fractal design cases, doesn't cost an arm and both legs Wasn’t even aware of this to be honest. I remwmber that when I started looking at building a pc mid last year I was like, dafuck?! €100 for cases? (Thinking they only cost a 10ner ) have learned heaps since MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x | NZXT Kraken X52 | MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro Wireless | Gigabyte Aurus AD27QD Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
