Will a third party fan hub work with corsair LL120 RGB fans?
jaiminator21
I am planning to do an upgrade to the 3rd gen ryzen cpus and with that I will change my case(at least try to, it depends on cpu+mobo prices) to the corsair crystal 280x with the h100i aio cooler and 2 LL120 RGB fans and I would try to still use the fans than come included with the case(doesn't come with rgb fans) adding to a total of 6 fans(aio on top(x2 ML120+ 240mm rad)+ x2 LL120RGB at thefront + x2 ML120 at the bottom). And I haven't found any stores(in spain) that sell the corsair hub other than corsair's web site. But they do sell other fan hub like this ones:
https://www.pccomponentes.com/aerocool-project-7-p7-h1-hub-controlador-rgb-para-ventiladores
https://www.amazon.es/Thermaltake-Commander-FP-Concentrador-Ventiladores/dp/B015KG6HP0/ref=asc_df_B015KG6HP0/?tag=googshopes-21&linkCode=df0&hvadid=82853727250&hvpos=1o2&hvnetw=g&hvrand=639400820513735638&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9061047&hvtargid=pla-260963482478&psc=1
I've also though of using something like this and connect it on to the mobo.
https://www.amazon.es/DEEPCOOL-Fan-HUB-Multiplicador-ventiladores/dp/B008YD7B0M/ref=asc_df_B008YD7B0M/?tag=googshopes-21&linkCode=df0&hvadid=301006161094&hvpos=1o1&hvnetw=g&hvrand=639400820513735638&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9061047&hvtargid=pla-404766633119&psc=1
Does anyone know if this two methods would work.
Thx
Will work for powering those fans but no rgb unless you get the corsair thing
Would it work through the motherboard??
Corsair RGB fans will only work with a RGB fan hub connected to a lighting node pro, or commander pro.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
