Monitor has volume slider but sound doesn't ,,exist"?
Solved by Derkoli,
10 minutes ago, Mr.Hans.- said:So I have SAMSUNG LC24F396FHUX monitor and have slider for volume which is on max and no sound, and I tried installing drivers and couldn't find right ones and does this monitor have speakers in it at all?
like @TrigrH said, there should be a little port on the back of your monitor with a little headphone near it or it might be green, its so you can use your gpu to output audio then the monitor acts as a dac to output 3.5mm
