Recommended AF fan and SP fan?
wolfie11
i need 2 AP fans and one SP fan
they need to have a black and white scheme!!!
thankyou
SP - Fractal Venturi or Noiseblocker eLoop
AF - Aerocool DS white
• OS: Windows 10/10 Pro  • SSD: Samsung 256GB 850 Evo Series *  • HDD: Seagate 1TB  • GPU: MSI GeForce GTX 1070 GAMING X (SLI)
• CPU: i7-4790K OC 4.7GHz Quad-Core Processor • Case: NZXT H440 (Black/Red) • PSU: EVGA SuperNOVA NEX 650W
• RAM: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory • Mobo: MSI Gaming 5
NEVER GO AEROCOOL DS. I own 6 and all had to be re-lubed not to mention they're fairly loud.
blackshades on
I don't have them, I just thought they fit the needs of OP :)
They suck MAJOR DILDOS. 111111111
blackshades on
I only have SP fans in my case - Noiseblocker eLoops :) there is only a single AF in my H440 and that is the stock exhaust fan
im not getting a radiator thanks anyway
Sorry, they are great static pressure fans, just assumed since you mentioned sp.
Don't want to sound like a dick, but aren't signatures limited to only 3 lines of text? yours is kinda huge
Ah, sorry. Didn't know it was only 3 lines of text. Will fix now.
i am sorry but what are Ap fans and Sp fans, never heard of them, is it static pressure or something?
AF - air flow
SP - static pressure :)
AF is air flow which brings as much air as it can through the case
SP is static pressure and used to bring air through objects in front like hard drive cage or radiator
It's only 3 lines m8
Yeah, because he "fixed" it :P before it was over 10
