H440 Water Cooling Build
Yenko
Hello all, this is my first attempt at water cooling, i have collect parts for servel months now, and just startet on my summer break, so now is the time to put it all together
Part list:
MSI Z77 Mpower mobo
Intel I5-3570K
8gb Kingston HyperX beats
Evga 780 Classified
XFX Pro 750w Black Edition
Ocz Vertex 4 128gb
Samsung 840 250gb
Cooling parts:
Hardware Labs SR-1 360
Alphacool nexx ST30 240
EK Supremacy Copper acetal cpu block
EK GTX 780 classy fullcover block
Alphacool D5 vario
Aquacomputer apualis D5 150ml res
3X NB-eLoop 800rpm
3X Noctua NF-F12
Swiftech and EK fittings
PrimoChill PrimoFlex adv LRT 13/10 White
System : I7-6700K EK-Supremacy. . Gigabyte Z170X-UD5 TH . 16GB Kingston HyperX predator ddr4. Evga Supernova 750 G2. Samsung 850 250gb. Samsung 840 250gb.
Evga GTX780 Classified EK-780 Classy . NZXT H440 White. Alphacool ST30 240. HW Labs SR-1 360. Alphacool D5 vario. aquacomputer D5 pump/res combo  . logi G502. CM Quick fire blue.  Dell U2515H.
Looks great. Needs more pics imo :D
[spoiler= My "gaming rig" ]
  • CPU: Intel i5 2500
  • Motherboard: Asrock B75M-GL R2.0
  • RAM: 1x4 GB 1333 Mhz Kingston, 1x4 GB 1333 Mhz Transcend
  • GPU: MSI GTX 770 Gaming OC 2 GB
  • Case: Zalman Z3 plus white
  • Storage: WD Blue 500 GB, WD Black 1 TB
  • PSU: LC POWER 650W ATX v2.3 80+ bronze
  • Display(s): Acer V223HQ
  • Cooling: Scythe SCKTN-3000
  • Keyboard: CoolerMaster QuickFire TK MX blue
  • Mouse: Sharkoon Fireglider Laser Mouse
I agree MOAR PICS. Every angle, especially of the WC stuff installed. :)
Bert & Ernie before squirting spermie.
Looks great so far :)
I love what you did with your mpower!  I did the same thing with mine as well  :)
CASE: FRACTAL DESIGN DEFINE R4  |  MOBO: MSI MPOWER Z77  |  CPU: Intel i5 3570k @ 4.4 GHz  |  CPU COOLER: NOCTUA NH-D15  |  GPU: EVGA GTX 770 SC |
PSU: CORSAIR AX860 W/ RED BRAIDED CABLES | SSD: SAMSUNG 840 EVO 250 GB | HDD: WD BLACK 1 TB | FANS: 3x NOCTUA NF-A14 | MONITOR: HP W2371D
KEYBOARD: CM STORM QFR MX BLUES W/  PBT KEYCAPS  |  MOUSE: LOGITECH G502 | MIC: AUDIO TECHNICA AT2020 | HEADPHONES: SENNHEISER HD 558
Hello here is a little update. Im almoste finish, i got all the cables and tubing done, made a bracket for the pump/res combo, i got to say there is not alot of room in a H440 for a pump/res, but i made it work, but if i was to do it again i would use a separate res.
This look great, nice job. Also thanks for more pics :)
Man, I love the H440, and this build to! It's just a shame you won't be able to see the reservoir.
Is it a monkey? Is it an ape? I don't care, I LOVE'EM!
Looks good!  That case is a fantastic watercooler.
Have you filled it up?  Got OC specs?  Temps?
 Not yet im going to watch the world cup in football to night, and maybe a couple of beers ;) so first tomorrow
Update, i got her filled up :) and no leaks, Temps are fine on the Gpu max 41´c with oc, but i think the Cpu runs a little hot, 56´c at full load with no oc. What did i do wrong, i tried to change the thermal grease, but that did not help.
Nice one mate I'm hoping to put my rig under water like this too when I have the coin
CPU: 4690k - 4.5@1.29v  GPU: GTX 780ti - core +100 / Mem+350 Motherboard: Asus Z97-A  SSD: 256Gb 840 Evo HDD: Seagate Barracuda 1TB  RAM: Corsair Vengance Pro 2x4Gb  Case: White H440  PSU: RM850  Cooling: NZXT Kraken X60
Just wondering, how did you black out the yellows and letters?
The MSI Z77 Mpower heatsinks have covers on them ( with the yellow accents on them ) they can be taken off from the actual heatsink its self, which is what the OP has done.
My Sig Rig: "X79 (3970X) -Midas"http://pcpartpicker.com/p/wsjGt6"  "Midas" Build Log - https://linustechtips.com/main/topic/59768-build-log-in-progress-code-name-midas/
"The Riddler" Custom Watercooled H440 Build Log ( in collaboration with my wife @ _TechPuppet_ ) - http://linustechtips.com/main/topic/149652-green-h440-special-edition-the-riddler-almost-there/
*Riptide Customs* " We sleeve PSU cables "
Wow I didn't know that, thanks!
how about the z97 mpower do you know if its possible there too?
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
I do not believe that on the Z97 Mpower that they do.
o gosh darn it. anyway ill just make a yellow accented build i dont mind that much
Yes the top heatsink covers were removed, but the lower one i had to paint, because the heatsink it self had some ugly bolt holes
Why can't anyone produce a proper black motherboard :(
But anyway, nice job watercooling an H440! I was thinking about doing something like that myself, but i didn't know where i could fit anything. Thanks for the inspiration :P
Specs: 4790k | Asus Z-97 Pro Wifi | MX100 512GB SSD | NZXT H440 Plastidipped Black | Dark Rock 3 CPU Cooler | MSI 290x Lightning | EVGA 850 G2 | 3x Noctua Industrial NF-F12's
Bought a powermac G5, expect a mod log sometime in 2015
Corsair is overrated, and Anime is ruined by the people who watch it
Yeah short from an uber expensive X79 motherboard from Asus or EVGA there isn't much. It's pretty hard to justify the cost of the Mpower if you're not an extreme overclocker too.
The Mpower boards aren't actually that expensive though. 200 dollars for the lower end one is fair for a high end motherboard. After all, Asus' entry level standard motherboard with nothing really to boast about is ~190
The EK-Supremacy cpu block comes with 4 different Jet plates,i have used the one it came with ( all around great performer), but does any one know if it will help temps to use the one for LGA-115X, because i think my temps on the cpu are on the high side, at 4.4ghz its at 60-65c, the GPU is only at 45-50c
This is how every H440 should look  :wub:
i5 4670k| Asrock H81M-ITX| EVGA Nex 650g| WD Black 500Gb| H100 with SP120s| ASUS Matrix 7970 Platinum (just sold)| Patriot Venom 1600Mhz 8Gb| Bitfenix Prodigy. Build log in progress
Build Log here: http://linustechtips.com/main/topic/119926-yin-yang-prodigy-update-2-26-14/
No thoughts about the EK jet plates
